so how much does regapping plugs effect tune?
Its basically down to the short with just the heads on now so Ill just pull it from the top.
Also talked to ARP today and they are sending me a free rocker stud since mine got a little damaged. Thanks ARP!!!!
LE is sending me new Valve seals for free. Thanks LLoyd!!!!
Every bit helps and really appreciate anything you guys can do!!! Thanks again!!
I just need about $150 in gaskets and Im good to start putting it back together
Anyone want to swing over and help me yank the motor out? Ive got some friends to help but none are into LT1s or have done a LT swap and the others dont care for cars.
The key thing to remember is don't bother taking the struts out from the top. Take them off the A-arms. It's far less of a pain. This way you don't have to worry about trying to align the struts back into the towers and having to force them into place... so on and so forth.
Here's a write up:
http://www.ace1252.com/LT1_Removal_From_Bottom/
I pulled alot of it just to see If I could find anymore missing bearings then just kept going since I didnt have the cherry picker and was working alone. All thats on it now are the heads and timing cover.
If it is down that far, you don't even need a Happy Hooker to get it out, just chains and a cherry picker and you are done... Hell, with help just undo the hood struts and hold the hood vertical until it is out...
Good luck with the tear down and reinstall!
