so how much does regapping plugs effect tune?
Edit...... Just got off the phone with Compcams they say they will at minimum get me new rockers, but have to talk to the warranty Dept about anything else. I sent him the pics and they said it deff looks like a got a rocker with poor porosity and it just broke. I asked if they have seen this b4 and he said 2 times since he has been with comp.
Minimum Ill get new rockers since the rocker bodies have the lifetime warranty.
The guy i talked with was really cool and if you zoom in on my pic of the broken rocker its easy to see how porus it was wich he saw and completely agreed. That rocker completely failed causing a complete tear down plus anyother damages. Hope they come through but I wont hold my breath for anything above the rockers.
anyways...when he was swappin motor in and out he was just dropping the whole front end out the bottom of the car..looked easier than trying to finaggle the motor out from under the cowl
Im doing it in the garage this time, no funds to have Speed do it. I have the motor pretty much ready to come out. How are guys lifting the body when dropping the motor?
Jack the car up, take front wheels off, loosen k-member, lower k-member onto furniture dolly, disconnect k-member and related components, jack frame up, move dolly w/ k-member and engine away from body.
You will have to have a significant amount of room to do this.
Make sure to at least drain the tranny fluid before doing this.
just my .02.....if you strip it down to the short block it should come out fairly easily....
