so how much does regapping plugs effect tune?
Scary part is about 20 of those bearings 2 pcs of the c-clip and part of the bearing race is in the motor. I pulled the intake found a couple pcs but alot more still MIA.
Ill pull the pan and see what I can find. Looks like the 355 is going in!!!
Yes its a Comp pro mag, I bought them new last Oct installed Nov and has less than 1000 miles easy
For the OP are you sure that there was no piston to valve contact?????
Whoops took to long to post and it is a promag
Something is definately amiss I have used promags for years and they keep their silver color.
Man, Comp Cams has been going downhill for years due to cheap manufacturing (probably due to sourcing cheap suppliers/OEMs), lack of Quality Control and in general probably flat-out greed to keep profit margins high.
I know I NEVER order an off-the-shelf grind cam without it being a "custom order" so that it is CNC ground and spun to verify dimensions. That is due to my personally diagnosing over a dozen bad cam grinds where the lobes were twisted down the axis progressively, back in the 1999-2000 timeframe. All where off-the-shelf master-to-blank non-CNC grinds. And yes, these were all LT1 grinds not only under Comp Cams numbers, but also for places like LPE.
I do know the new Comp Cams Ultra-Gold rockers are actually Scorpion Pro series rockers. Hell they come in the same box as the Scorpions no less. Just that thye are Cheaper through Summit and such compared to buying the Pro-series Scorpions through a Scorpion vendor.
The Comp Cams studs are also all made by ARP (even are stamped ARP), so those are a safe-bet as well.
I say screw the Comp-R lifters as well, as I have had problems with a newer set with them either not pumping up, improper hydraulic action, or them "sticking" and allowing excess lash. I am putting in a set of LS7 lifters as we speak and am almost scared to see what I find once I pull those POS Comp-Rs out. I am hoping to find no damaged rollers and no damage to the cam lobes, otherwise it is a cam swap for me. (New 383 motor with less than 1k miles on it here)
One thing for sure is they are Pro Mags I bought them myself and even still have the box
