tb question and stall question.
i didnt say you couldnt.. i said it is not probable.. because it isnt..
most ls1 a4s have a difficult time clearing the 400rwhp mark by a good margin.. so you cant tell me for a second the chances for an lt1 making that are "very" attainable..
you need to remember, were talking stalled a4s with gears.. not m6s..
i promise you that 500rwhp (which i doubt it makes this to the ground, or it is a VERY VERY generous dyno.. please correct if im wrong) is an m6.. probably has low gears.. does not have a 9 inch or 12 bolt small street tires.. etc etc etc..
I am clarifying to you that with the right combo and tuning, 400HP is easy. Most LT1 owners just throw stuff and HOPE for 400 HP. Others build their cars to MAKE 400HP. You'll also find that the guys who build with intention do their research, make comparisons to similar combos, regardless of gearing, stall, rear, etc. I'm just thinking maybe you should give this guy some hope, because what he's asking for is not impossible.
Besides, dyno numbers don't mean much anyway. My pig hasn't been dynoed, and I'm an auto through a 9". I could care less what it puts down as long as I'm ETing what I am.
the one at 430rwhp, is it an a4 or an m6?
YANK STEALTH 2800 LT1
298mm, 2800 Stall, 1.90 STRStock appearing converter that delivers a noticeable improvement in acceleration over stock. 3 tenths reduction in 1/4 times are common.
$500, I have $950 cash right now going to order this and a 52 mm tb from bbk or holley.
Not planning on running it on track until the 26th, so tires will come then.
There are inherent advantages to both types. Either way, the motor itself would still put out the same power regardless of what transmission is bolted to it.
thanks
415 isnt too much over the mark..
how huge is his cam?
my point is... ls1s have give or take 40rwhp advantage... and most a4 ls1s have a hard time hitting 400rwhp H/C.. so it is VERY hard for me to believe it is "Easy" to do with an lt1.. possible? yes... but not likely..
so because i have an ls1 i dont know **** about lt1s.. sounds about right... wrong.
i have a fairly good bit of knowledge on what they are capable of.. do i think you would pick up 60rwhp out of a head swap and a little bit more duration.. hell no.
but please, do it and prove me wrong..
again.. i can tell you for infinity seconds that for stalled lt1s 400rwhp is NOT the norm.. no where close.. i have yet to see a link to one.. one guy posted up one with 430rwhp IIRC and it ended up being a six speed car..
what you guys cant tell me for a second is that lt1s hitting 400rwhp is "easy" when its not even easy on an ls1...
factory the ls1s have around a 40rwhp advantage.. mod for mod they pick up more hp/tq than an lt1... it isnt "easy" to make a stalled a4 ls1 hit 400rwhp.. if im wrong, please show me *multiple* threads of stalled a4 lt1s hitting 400rwhp H/C..
im not being biased, im being truthful. how about you quit being naive and look at facts..
please show me where all these 400rwhp lt1s are..
i DRUG one last night at the track.. AFR heads big cam big converter etc etc ect.. its a "drag car".. then he sprayed a 100 shot and ran the same times i was..
its hard for me to believe most a4 lt1s with H/C have 400rwhp when thats about what i make and absolutely destroy them..
im sure most of you know i am right... im done with it.. have a nice day!
i hope i never run into you, don't want my **** getting destroyed
its like everyone who has an ls1 is an expert and runs 12s stock, what a joke. this argument is pointless since you will never accept anything i say. if you really want to learn though, go do some reading on lt1's.
its like everyone who has an ls1 is an expert and runs 12s stock, what a joke. this argument is pointless since you will never accept anything i say. if you really want to learn though, go do some reading on lt1's.i never said i was an expert, i have said i could be wrong and to pleae point me to something showing me i am.. nobody has yet... why? because its not "easy" to go find a ton of threads with stalled lt1s at 400rwhp..
and yes, it probably is better you dont run into me.
my last setup went 7.2s@95.5mph spinning/hitting rev limiter/not tuned for heads in 90 degree weather..
both those times are on motor.. the 7.2@95 was a "budget build", if i had the money it would have been much faster..
your acting like i bought a stock car and came in here talking ****...
my times are in my sig.. maybe you should glance at them before saying **** like that..
7.80s...
they are newer, and they are better... if you cant agree on that........ well.. you get the point.. (FWIW i think the lt1 is also a great platform.. but your just ignorant/naive if you cant say the ls1 is a superior platform)
you guys are funny....
thank you..
i run 7.40s@91.5 hot lapped.. that a full weight car with a/c radio big fat stock tires up front 317 heads
7.80s...
Your shifter is gummed up from soda being spilt from the shitty *** designed cupholder.
Just take the console out and clean the plastic slider w/ water and a rag, i have done mine several times...
