max compression ratio
Old Jul 16, 2009 | 01:39 PM
saylorZ28's Avatar
Default max compression ratio
ok i have a set up for 11;4;1 cr and i am wondering if that will be safe to run 93 + oct since lt1 is reverse flow can i get a away with that ratio ... plus it will have the squeeze.. 150 shot ... someone tech in
Old Jul 16, 2009 | 01:48 PM
duh's Avatar
duh
I don't see it being too bad, just make sure to run 92/93 whichever is higher in your area. Maybe look into the dynamic compression ratio calculator and see what that sits at. If your dynamic is much higher than 9.5:1 then you may want to double think your course of action.
Old Jul 16, 2009 | 01:59 PM
ss.slp.ls1's Avatar
^^^Exactly, calculating your DCR is your best bet.
I think you should be fine on 93 octane though.
Old Jul 16, 2009 | 02:01 PM
RamAir95TA's Avatar
You can go much higher than that (SCR considered). It's in the tune.
Old Jul 16, 2009 | 02:21 PM
duh's Avatar
duh
without cam specs and specifics for the engine you can't figure DCR and therefore can"t confirm what we all think, that he'll be fine.....
as for SCR I speced out a 414 with a SCR of 12.4:1 with a DCR of 9:1. With those numbers I could run 93 or even a boosted application (with some race gas) and really make some hp.....
Old Jul 16, 2009 | 02:22 PM
94Z28rag's Avatar
Nitrous loves compression.
Old Jul 16, 2009 | 02:28 PM
kinglt-1's Avatar
agreed with above post. The op should not have any problems with that compression on pump gas. Good tuning is key!
Old Jul 16, 2009 | 03:02 PM
za355tx's Avatar
Honestly 11.4 is not that high. My setup before I parted was 12.4 scr and I didn't have issues. Lloyd Elliotts old car had a 13.1 scr so yeah you can get away with alot.
Old Jul 18, 2009 | 07:14 PM
saylorZ28's Avatar
well i was goin to run an cc503 on this setup with ported heads and a 355 short block... but i've been thinkin bout the 383 and wonder how a 503 would act with it ...
Old Jul 18, 2009 | 07:29 PM
RamAir95TA's Avatar
While it would be "fine" by most standards, you can get away with something much bigger. You need more duration and lift to fill the cylinders of a 383. I would look for something in the 23x+ range closing in on .600 lift.
Old Jul 18, 2009 | 09:22 PM
LT1nitrouZ's Avatar
Where can I find said dynamic compression ratio calculator? and what is the difference between the normal interpretation of compression ratio and dynamic compression ratio?
Old Jul 19, 2009 | 05:43 AM
gregrob's Avatar
I'm tired. Google it
Old Jul 19, 2009 | 06:11 AM
duh's Avatar
duh
do a search here on tech and you should find one or two threads on it, just takes some looking.....BTW ^+1 I'm going to bed.....
Old Jul 19, 2009 | 01:43 PM
saylorZ28's Avatar
i geuss i will stay with a 355..
Old Jul 19, 2009 | 01:59 PM
NightTrain66's Avatar
LS1TECH Sponsor
here is a good DCR calculator.
http://www.wallaceracing.com/dynamic-cr.php
Just plug in the #'s listed and you will see how the IVC effects the DCR.
CC 503 is a descent cam for someone needing to pass emissions and a very mild gear/stall set up wanting a 6200 RPM shift point.
If you do not need to pass emissions, want to shift at a higher RPM and/or have some gear/stall, a larger cam would probably be more what you are after.
Lloyd
Old Jul 20, 2009 | 12:58 AM
LT1nitrouZ's Avatar
So with a good tune then 8.89:1 DCR would be fine to run on 93 octane judging by what has been said.
This topic is of particular interest due to the fact that the car I just bought has a 12:1 compression 396 and I need to get it to run safely on pump gas... horsepower doesnt matter on pumpgas, I can put a racegas tune in it at track. I just need to get from point a to point be safely on 93 octane.
