Pro-form
Old Jul 16, 2009 | 01:39 PM
SPOOOOLIN's Avatar
Default Pro-form
Pro-form rockers??? Ya or na
Old Jul 16, 2009 | 01:44 PM
duh's Avatar
duh
used 'em on my 90 with the GM 847.....They were actually quiet for roller rockers. I'd buy em again, they're relatively in expensive as well.
Old Jul 16, 2009 | 02:02 PM
ss.slp.ls1's Avatar
There was a thread recently titled something like "Proform vs. Comp" and the poster was torn between using Proform or Comp rockers. The general consensus is to go with the tried and true Comp rockers.
I recommend Comp 1305-16 1.6 NSA 7/16" full roller rockers. They will require ARP 7/16" rocker arm studs and guideplates (I use TrickFlow guideplates).
Old Jul 16, 2009 | 02:10 PM
shbox's Avatar
Made in China makes them cheap and inexpensive.
Old Jul 16, 2009 | 04:25 PM
Counted Out's Avatar
I remember reading about one guy who had a set and his exact words were:
"I wouldn't put them in my lawnmower"
But then again, some people have tried them and said they are great. You can get Scorpion Roller Rockers on Ebay for around $230 shipped - Made in the USA.
Old Jul 16, 2009 | 04:30 PM
96capricemgr's Avatar
I used ProForm on my ZZ4 cam only setup, worked just fine, still in good condition.
I would NOT use them on the current heads and cam setup though.
Old Jul 16, 2009 | 10:24 PM
myltwon's Avatar
I've had good luck with mine but I'm not turning any rediculous rpm nor have a gigantic cam
Old Jul 16, 2009 | 10:32 PM
ADM's Avatar
ADM
LE suggested them to me to use with his 218/224 cam, thats why I asked about them on here. Maybe they work will a small cam like that, but he grinds a hell of lift on it for a cam of its duration.
I am going for Pro Magnums full rollers, and paying the difference on the proven product. But trust me, Made in China does not mean crap quality anymore. It can be made with the same alloy as Crane uses in their Gold rockers, but be cheaper because of China having cheaper labour. It works in your favor as a customer.
Good luck.
Old Jul 16, 2009 | 11:05 PM
shbox's Avatar
Good luck.
The problem is, with all the known bad quality things coming out of China, you just don't know. Unless I have some specifics, I'm not taking chances.
Old Jul 17, 2009 | 12:58 AM
BLK,97,T/A,M-6's Avatar
I've only got like 300 miles on mine, but that said they are quiet. So far I am very pleased with them. If I had lumps of cash laying around, I would have went with something a little more high end.
Old Jul 17, 2009 | 04:58 AM
monster81's Avatar
i recently bought the summit Aluminum RRs for like $200 ,,havent installed them yet but heard some good news bout them in other threads i read in the past..i believe they are the Scorpions RRs sold as a summit brand,they look very identical
Old Jul 17, 2009 | 05:26 AM
I really, REALLY doubt that. Summit doesn't even carry Scorpion Roller Rockers.
Old Jul 17, 2009 | 06:39 AM
ADM's Avatar
ADM
One thing I like about the Proforms is the side stops on the roller tips to help keep the rocker arm on the valve tip.
Thats something that the Pro Magnums don't have, and neither do the Ultra Pro Magnums have them. Thats making me consider getting the GM 1.6s that come with the LT4 kit.
Old Jul 17, 2009 | 07:08 AM
shbox's Avatar
Umm...probably because they are SA rockers? I haven't checked the UPMs, but the Pro Mags can be had in SA (with the "side stops") or NSA (without). NSAs are the better choice for frequent high RPM use.
I've read too many threads about the Proforms destructing and filling the engine with metal to be confident they are safe to use. Then again, some people like them.
Old Jul 17, 2009 | 07:12 AM
ADM's Avatar
ADM
I know its because they are self aligning. But I even checked the Comp Cams site, and they don't advertise the Pro Mags or Ultras with side stops, even though they are self aligning. Or maybe its just the picture.
I would prefer having the side stops, just for the peace of mind.
Old Jul 17, 2009 | 10:39 AM
Z-RATED94's Avatar
You should probably do a little more research. If their SA, they have to have the tabs to keep them on the valves. How else would they stay on?
Old Jul 17, 2009 | 10:44 AM
ADM's Avatar
ADM
I said they don't advertise them having them, as there are no pictures showing they do have them. All SA rockers are advertised with the model having the stops.
Of course they must have them to stay on the valve. I did not say they don't, did I?
Old Jul 17, 2009 | 11:20 AM
ss.slp.ls1's Avatar
http://www.summitracing.com/parts/AFR-6032/
Old Jul 17, 2009 | 05:58 PM
Originally Posted by ss.slp.ls1
Woahhhh. Didn't know that.
They use different part numbers for them there though - that's pretty stupid.
Old Jul 17, 2009 | 06:52 PM
shbox's Avatar
I wonder what these little babies are (check in the circle at the bottom of the page)? Isn't a catalog kinda like advertising?
http://www.compcams.com/technical/Ca...106-07/269.pdf
