Engine build advice..355 or 383??
Old Jul 26, 2009 | 10:57 PM
  #41
97Z28SS's Avatar
For me it comes down to this if your stock crank is fubar'ed and you have to buy another crank anyway then I'd build an all forged 383 but if the stock crank is good then just get rods and pistons and do a 355. The price difference is going to be the cost of the forged 3.75" crank if you have to buy rods & pistons for the 355, so I would just do the 383.
Old Jul 28, 2009 | 09:11 AM
  #42
WS Sick's Avatar
Originally Posted by FASTFATBOY
I wouldnt use the stock powdered metal rods BECAUSE you cant put good rod bolts in.
95 Formula on this board went 10.30's with a 355, solid roller STOCK CRANK all motor and a six speed. He was spinning it past 7000.
Why can't the good bolts be put in?
Old Jul 28, 2009 | 01:02 PM
  #43
96blackz28's Avatar
Originally Posted by 97Z28SS
Check with AD Performance they cal sell you a complete 383 all forged rotating assembly with Scat 4340 standard weight crank, Scat 6" Procomp 4340 rods and Mahle forged ft coated pistons for $1600. Then get Pro Gram splayed billet 4 bolt caps and have them installed with a .030 overbore, deck the block and align bore/hone the mains then use ARP head and main studs. Also get one of Shon Herrons billet oil pump drives get your heads & intake ported by Ai or EPortworks and get a matching cam (be sure to indicate an emissions cam) then get a larger capacity oilpan and you'll be good to go.
Check out ohiocrank man.. they got a all forged internal balanced 383 complete rotating assembly wit 6" rods for $1295.. thats whats going in my 383 build.
