Post pix of your LT1 engine.
Old 01-23-2017, 09:27 AM
  #581
Chevellebill's Avatar
Default Lt1 in 69 chevelle
This is my lt1 with a few mods and a older paxton
Old 01-23-2017, 03:37 PM
  #582
dlwilson's Avatar
LT1 from 1996 Caprice into 1991 Jaguar XJS
Old 01-23-2017, 05:39 PM
  #583
Evaporate's Avatar
Originally Posted by T/A KID
Seen this thread doing some searches and figured I would give it a bump.. logs of clean setups!!!
figured I would share a pic of an LTX I've been working on
you've got some 'splaining to do
Old 01-23-2017, 10:17 PM
  #584
GrnDragon's Avatar
Currently under the knife, rebuilding the engine after about 100 miles of use...still hurts to write.
Engine bay took a crap ton of work.
Old 01-23-2017, 10:50 PM
  #585
T/A KID's Avatar
Amazing!!!!
Let me know when you get it back together and we can do some more tuning
Old 01-23-2017, 10:53 PM
  #586
T/A KID's Avatar
Figured the setup would raise an eyebrow or two
Ill post up some more info when I finish it... but it's a reverse drive Novi blower (from a c7) and the intake started life as a edelbrock pro flow
non intercooled running E85 (actually around E68 year around in my parts of the woods)
pic above I dis a custom setup... using the ATI big block hub and universal 10 rib pulley I decided to position the blower pulley BEHIND the ATI damper
IMO the lever arm for extending the blower pulley on the crankshaft puts a lot of undue stress on the crank/mains, is with a reverse drive you have much better inlet options and usually a shorter belt which all helps
Old 01-24-2017, 11:05 AM
  #587
Reaper-Z's Avatar
My old '95 Camaro Z28 engine bay. Minor bolton's but still ran 13.8 factory freak!
Old 01-26-2017, 12:34 AM
  #588
LTX396's Avatar
Size:  221.4 KB]Name:  IMG_0383_zpstdqf7hvp.jpg
http://
Old 01-26-2017, 09:33 AM
  #589
Reaper-Z's Avatar
^^^ That's beauty! How much power? Specs?
Old 01-26-2017, 09:16 PM
  #590
LTX396's Avatar
- 396 ci
- scat 4340 competition crank
- scat 4340 h-beam rods
- Comp custom grind hyd roller cam
- Wiseco forged pro-tru nos pistons
- AFR Eliminator 195 (55cc) heads
- Moly push rods
- Comp ultra pro magnum rockers
- EFI 24x
- Kooks Long tubes
- ATI super damper
- Edelbrock intake
- Holley 58mm TB
- Moroso oil pan
Engine is built for a 150 shot.
N/A Dynoed at 453 rwhp / 427rwtq.
Old 04-24-2017, 11:46 PM
  #591
T/A KID's Avatar
Rough draft.... have to finalize several things, but getting close to fire up!!
Old 04-25-2017, 11:51 AM
  #592
1970CSTLT1's Avatar
LT1 swapped 1994 Chevy Cheyenne
Old 04-25-2017, 07:27 PM
  #593
SRZ
SRZ's Avatar
Looking good man. You pulled the heater off that thing too? Digging the intake too. Like the belt guard.
Old 04-25-2017, 08:25 PM
  #594
T/A KID's Avatar
THanks SRZ, been a minute man!!! This car set long enough, thought it was time to start some attention.. removed factory heater, but had aftermarket unit under the dash 👍🏻
Yea Intake should be solid for the combo with runner length and humpback plenum
Old 04-26-2017, 09:57 PM
  #595
stevo9389's Avatar
Haz boner. Weren't you the guy selling a home made twin screw intake a while ago? If so, what happened?
Old 04-27-2017, 07:50 AM
  #596
T/A KID's Avatar
Yep that was me!! I like to fabricate things, kind of my thing ha... it was a cool unique setup!! Whipple told me it couldn't be done, so I did it!
Old 04-30-2017, 10:09 PM
  #597
96lt1m6's Avatar
1995 Formula 81k she is a virgin lol not for long
Quick Reply: Post pix of your LT1 engine.
