View Poll Results: Would you buy ARP LT! Pressureplate bolts if made?
Voters: 32. You may not vote on this poll
ARP Pressure Plate Bolts....
Mcleod PN you posted on the first page is not even in Mcleod's catalog, not to mention they told me that number does not exist. It Most likely is a prepackaged set of stock GM bolts that are no longer available. If you have a link to said bolts through some distributor please post it up. As it stands right now there is no aftermarket replacement for the Pressure Plate Bolts.
-Kevin
-Kevin
Obviously, someone lied to you.
Hey Guys,
I ran into the same difficulty finding pressure plate bolts for LT1. My solution ended up coming from Fastenal:
Part No. 20677 HCS 3/8-16 X 2 YZ9 $1.03 ea.
These are grade 9 bolts with a yield strength rating of 180,000 psi. I now have the clutch installed and getting ready to bolt up the transmission. Hope this helps...
