Did OTVC last night...
Took me probably a few hours. I don't have any pics but I routed them just like this except with MSD wires. If you use the made 4 you looms with MSD wires (I did) you will probably want to drill them out just a tiny bit. Otherwise they don't go around the wires quite right because they are meant for 7-8mm. No big deal though. Doesn't take a full minute on each one.
http://www.lt1engine.com/tech/how-to...e-cover-wires/
Where are you guys running the wires on the passenger side down to get to the Opti? Also, are you guys doing this with a stock replacement wire kit or do you need some kind of make it yourself kit? I know the boots and connectors are different on the Opti that's why I'm asking.
They are make it yourself. Taylor makes a set and so does MSD. I think a few other companies like Accel make them too.
The looms Thunderracing sells are Made-4-You looms. Same stuff.
I picked up a cut to length kit of MSD's for 40 bucks yesterday at the auto store. It was 90 bucks but when he rang it up he adjusted it to 40 who knows why but I'm not complaining! Of course I still had to buy the Opti boots at 12 bucks per pair. But still under 100 bucks for cut to length wires. Now all I need to pick up are looms.
