HELP ! I Nedd Piston Part #'s !!!
Old Jul 30, 2009 | 11:38 AM
djjab57's Avatar
Question HELP ! I Need Piston Part #'s !!!
Im building my 355 .30 and need the part # for the Mahl and the Speed Pro Forged pistons using stock rods & crank 10:1 compression
Thanks James B.
Old Jul 30, 2009 | 11:51 AM
myltwon's Avatar
what length rods?
Old Jul 30, 2009 | 11:54 AM
djjab57's Avatar
sorry i left that out, im using the stock rods and crank
Old Jul 30, 2009 | 12:11 PM
myltwon's Avatar
what compression you want? stock, lower, or higher?
hyper or forged?
Old Jul 30, 2009 | 12:23 PM
djjab57's Avatar
forged and im thinking 10:1
Old Jul 30, 2009 | 04:21 PM
AChotrod's Avatar
Unless your going Turbo or Super charger, I would bump up the compression a bit.
Old Jul 30, 2009 | 04:26 PM
vanilla89's Avatar
Yeah, 11.5:1 or 12:1 would be fine.. I would also go with a 6 inch rod..
Old Jul 30, 2009 | 05:17 PM
Corey @ Clayton Racing's Avatar
The MAHLE number for that combo is sbc550030f05 It's 10.6 with 64cc head. But like others said rour better off putting in a longer rod since its apart and got to be rebalanced anyway.
Old Jul 30, 2009 | 05:21 PM
djjab57's Avatar
thank you ! and are these something you sell at your store ?
Old Jul 30, 2009 | 09:30 PM
myltwon's Avatar
I have over 12:1 SCR in the FL heat on 93
don't be skurred of a little compression, just make sure you get a cam to compliment it
Old Jul 31, 2009 | 09:40 AM
djjab57's Avatar
this is the cam im going with from LE
223/230 .565/.565 112 LSA.
Old Jul 31, 2009 | 11:29 AM
myltwon's Avatar
this isn't an "off-the-shelf" LE is it?
depending on compression you might want a bigger split than 7 degrees, I know when lloyd spec'd my cam he put in a 12 degree split, but then again this is a car that gets driven every day and won't see race gas
Old Jul 31, 2009 | 11:36 AM
djjab57's Avatar
yea, the one he has as the largest emmison friendly
Old Jul 31, 2009 | 11:48 AM
myltwon's Avatar
make sure you get him to spec you one, doesn't cost anymore
Old Jul 31, 2009 | 09:00 PM
Yes we sell a lot of MAHLE piston kits.
