Dynotuning Le1 heads 306 cam with 110 octane. Advancing timing give noticable gains?
Alright I plan on buying another PCM to use specifically for drag racing with high octane fuel. I only want to dynotune once due to pricing. So since I will be using 110 octane and be able to advance timing will I get any noticable gains over normal timing with le1 heads and a 306 cam all motor? Compression is around 11:1 Thanks for any help.
there is no need at all to run 110 in anything like that, and since your engine does not NEED it, it will slow you down.
You can probly pick up a bit from a good tune on the dyno from what you have stated you have now. just adding timing and compression does not equal more power. It may sometimes, not on everything.
I have seen cars where you pull total timing out and it did not lose anything, have seen other where 1 degree loses 25hp.
You don't need 110oct for an 11:1cr 306 build. Remember that higher octane makes LESS power unless it allows you to run timing that would detonate at higher compression ratios. 11:1 is low compression for an LTX, and 306 is a lazy cam lowering effective CR even more and would probably perform just as good on 93 as 110.
Race gas won't make you much faster unless you need it.
while on the dyno
With the car on the dyno you can watch your tuner gradually adjust the many variables. As he tweeks the timing there will be HP and Torque gains with timing advances. As he continue the gains get smller and the engine noise will be perceived by the ecm as knock. then it will retard the ignition timing automatically. YOUR MAX GAINS WILL BE WHEN YOU DESENSITIZE THE Knock MODULE WITH A REISTER OR A complete LT4 SET UP- LT4 SENSOR + module. We are talkng very small. but important gains. Make sure the MAF is clean, the injectors are 30 lbs or slightly more and getting plenty of cold air.
