high speed drivetrain vibration
Old Jul 31, 2009 | 11:24 AM
Drift_king2007's Avatar
Default high speed drivetrain vibration
T56 with 147,xxx miles mods are in my sig. Mainly in high rpm range, 3rd gear, and 4th gear, 135 in 5th gear (no faster cause the vibration is horrible) did I mention I hate vibrations!
any ideas, tranny just worn? rear tranny yolk bushing? help!!! i hate vibrations!
Old Jul 31, 2009 | 11:26 AM
hitmanws6's Avatar
the big 3 im thinking are the culprit are your motor mounts, out of balance tires or your driveshaft is out of balance. but then again 135 wasnt exactly meant to feel comfortable in our cars
Old Jul 31, 2009 | 11:34 AM
myltwon's Avatar
pretty much +1 to everything he said^
Old Jul 31, 2009 | 11:44 AM
ss.slp.ls1's Avatar
Old Jul 31, 2009 | 12:58 PM
z_speedfreak's Avatar
140 is smooth as silk in my car. do you have an LS1 DS? hows the tranny mount? def check the tires too.
Old Jul 31, 2009 | 01:30 PM
ss.slp.ls1's Avatar
Up to 160 smooth for me.
Old Jul 31, 2009 | 01:32 PM
its all stock LT1 drivetrain... lol, tires are smooth as glass at 80 in 6th... i was just wandering if the tranny has a little wear, the rear output bushing seems like it has a good amount of play in it? the motor mounts are good, the tranny mount needs replacing... (that is prolly the majority of it) i just wandered if you guys had the same sort of problem... prolly no big deal.
Old Jul 31, 2009 | 01:35 PM
ss.slp.ls1's Avatar
How did you verify that the motor mounts are good. You can't just look at them. Replace the trans mount. Get a LS1 alum ds and see if your vibration is still there.
Old Jul 31, 2009 | 01:38 PM
lol yep smooth here too, just very..light feeling
sounds like you might of found your problems also check your pilot bushing.
Old Jul 31, 2009 | 08:40 PM
replaced them about 2000 miles ago when i built the motor.
tranny mount is a for sure next thing, i will look into the DS.
thanks for the help guys!
Old Jul 31, 2009 | 08:41 PM
thanks! will do!
Old Aug 2, 2009 | 07:39 AM
James Montigny's Avatar
With rubber or poly?
Old Aug 2, 2009 | 07:47 AM
2nd Gen Fl 'bird's Avatar
My buddy's wife had a vibration crop up on her LT1 car(6 speed). Turned out to be the drive shaft. Slung a weight off. Seems to be a common problem.
Old Aug 3, 2009 | 07:16 AM
rubber motor mounts, I am going to get a poly tranny mount though...
Old Aug 3, 2009 | 07:17 AM
thanks, looking for an LS1 aluminium driveshaft.
