crank hub Q
is this a crank under drive pulley?
edit: which AI cam did you go with?
hahah rust proofing! nah I'll clean it when I get it all stripped down
o no you dont have to mark the hub just match it up w/ the key on the crank. the key on the crank should be matched w/ the crank sprocket.
and are you asking about the valve springs cause I need to do that 1st? ...probably huh cause I'm not supposed to move the crank after taking the hub off right?
I realize I'm over my head here heh, just taking it slow, reading everything twice and jumpin on here when I have questions. wish I had the $ to have this done, I was only trying to fix an oil leak and dropped $400 on having the rear main done but it turned out to be the intake mani, so I figured I would cam it and my buddy said he'd help me so..here I am now
and thanks for the help everyone!
Also it doest really matter how it comes out its putting it all back in that matters, ie ..setting the rockers and making sure you line up the timing dots. The cam can only go in one way if the dots are lined up. I made sure my crank was TDC on the #1 cylinder compression stroke to be safe. Oh if your doing it with the heads on the car make sure every piston is TDC when doing the springs so the valve cant drop and use compressed air to hold them up
and here is how it should work:
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
