Snapped Pushrods....
See this animation for reference:
http://shbox.com/1/cam_timing_ani.gif
#6 TDC, Cam Gear at 6, Crak Gear at 12, Doewl Pin at 3
Got it this time! lol. pulled out all the old bent valves, turned out it was ONLY the intake valves bent. All of the exhausts were perfect.
Checked how I had the cam installed and when I had #1 at TDC, the dowel pin sat at the 11........I was WAY off...
The heads and pistons are good to go, so we are seating the new valves tomorrow and re-installing the heads. New pushrods will be ordered Sunday morning, new alternator (because mine took a ****) will be ordered Friday morning and arrive Friday night, and new header bolts will be here by friday as well...car will be back up and running (knock on wood) Friday afternoon!!!
Jesus Christ man, you realize they are connected by a chain right? And NOTHING you do will realign them short of taking off the timing cover, putting it at TDC, and THEN lining up the dots...?
Damn dude, come on
You also said "EVERY SINGLE EXHAUST VALVE WAS BENT" now you say they're all good and it was only the intake valves. Which is it? Or do you even know thw difference?
Lol
The exhaust valve thing was a typo. I meant to say intake valves and yes Calvien you jackass, I know the difference.
Originally Posted by JohnnyFormula View Post
See that's how you talk to people asking for help! It's text so even if you are joking the reader can't tell body language and tone of voice and he's already pissed off get what I mean?
"See how I talk to people asking for help" ????
How else do you explain to somebody that they're trying to tackle a project that they don't have the mechanical experience and knowledge to successfully complete? I was simply using HIS words, and the phrasing of HIS questions to show that he's not experienced enough to accomplish what he's trying to do.
You may be trying to defend your friend, and that's very nice of you. However, anyway you cut it, he's in over his head!
Re read what I posted I said that's HOW not see how I. You wanna be a dick that's cool. And yes he was over his head but he learned from his mistakes and that's what life is about.
Cory,
You'r welcome buddy.
Furthermore, I may have been critical of your friend's limited automotive knowledge, but at least I was reasonably polite about it. Maybe YOU should re-read the other posts, as several of them were pretty rude and crude......no offense intended to those posters.
you are the biggest idiot ever! way to **** up a nice SS.
I admitted that asking about the timing cover was a stupid question, and I realized it the second I looked at my ******* car again! I was not thinking clearly when I asked that and it was a dumb ******* question! I didnt ACTUALLY try and do it.
I made an honest mistake. I have owned up to and corrected that mistake like a grown *** human being...And the SS is not "fucked up" it just needed a couple more things fixed. It will be perfectly fine in a few days. I dont need you to chastise me, I came here for advice and for help so I didnt repeat a mistake, not for people to insult and degrade me when I am already down. So do me a favor and take your comments somewhere else. To those of you who actually helped me, thank you.
Just slow down and take the time to learn what you're working with does, before you start a project.
A solid understanding of how an engine works and what a camshaft does, specifucally, would have prevented most of thos via "common-mechanical sense".
Hope all goes well for you from now on.
Got new valves seated and looking good, heads are back on the car.
Re-positioned the camshaft to the proper position and this time I am sure of it.
Johnny and I measured pushrod length and came out with the stock 7.2" length, so I have ordered Trick Flow Chromemoly 7.2" pushrods
We used the stock 7.2" pushrods I still had to set the valve lash CORRECTLY...we hand turned the crank and set each valve ensuring I could hand turn the crank completely 2 times each valve before moving to the next.
I will put in the new pushrods when I get them on wed and once they are all installed I will hand turn the crank again to ensure nothing is binding up. If all is well I will crank her over without the injectors connected so it wont start, and I am gonna re-check the rockers to make sure nothing goes wrong...just a precaution...
Once that is done I will reconnect the injectors and start her up...
