weird car died when driving...
Old Aug 3, 2009 | 10:22 AM
sdotlog's Avatar
Exclamation weird car died when driving...
Ok so I'm on the way to the park on this windy 3mile road going 35-45 mph. Car ahead of me was going extremely slow. I get over and punch it, to pass the car up and accel was kin of poor. Few mins later car just looses power like symptoms of being out of fuel. I had more than half tank left. Thinking my fuel pump is beggining to fail? Injectors still stock, I do have 36lbs sitting now just hadn't had the time to get another tune. Any ideass? Might have to order that racetronix fuel pump kit sooner than in thought.
Old Aug 3, 2009 | 12:11 PM
ss.slp.ls1's Avatar
Test your fuel pressure before you buy a new pump. Test for spark at the coil while you are at it.
Old Aug 3, 2009 | 12:21 PM
sdotlog's Avatar
will do.. forgot to add that when i pulled over... checked under the hood and underneath vehicle for anything odd. hopped in car and started fine. Parked it when got to the park and drove home about 35 miles back home trouble free.
Old Aug 3, 2009 | 12:30 PM
ss.slp.ls1's Avatar
Might be a fuel problem under load.
Could also be the ICM.
Old Aug 3, 2009 | 01:01 PM
riceburnerZ28's Avatar
thats been happening to me the last few weeks turns out it was a bad coil. I also agree with the previous post...do the basic tests first and check for codes!
Old Aug 3, 2009 | 06:30 PM
sdotlog's Avatar
Engine light didn't come on so would there be codes up still? Any basic fuel pressure tester would work right? And how to check coil for spark? Sorry not very tech savvy.
Old Aug 3, 2009 | 06:35 PM
ss.slp.ls1's Avatar
It's possible.
Yeah, screw it onto the schrader vlave of your fuel rail.
Testing for spark at the coil isn't needed. I didn't know that your car started back up again. You can test the continuity of the coil though.
Old Aug 3, 2009 | 07:04 PM
sdotlog's Avatar
Originally Posted by ss.slp.ls1
It's possible.
Cool. Thanks man. Ill stop by the parts store for that tester. The how to's on shbox's website should guide me the rst of the way. Thanks again man, ill let you know the results of both tests
Scratch it. I'll just order the racetronix kit end of next week. I don't feel like spending 45bucks to find out i have to spend the 200bucks i was anyways down the road for the new fuel pump kit. I'll just try and test the continuity of the coil tonight if i can.
Old Aug 4, 2009 | 09:39 PM
sdotlog's Avatar
Alright tested fuel pressure.. held steady at 40psi idle and a little below 40psi under a load. Haven't checked the coil yet tho...
Old Aug 5, 2009 | 12:09 AM
sdotlog's Avatar
so i looked at shbox. the ignition coil is completely different from mines.
