Patriot Valves vs. Manley Valves?
Which ones are better? I know nothing about valves. I have the AFR heads modified by TPiS which are 187cc AFR Heads with a 54cc compression chamber, 1.65 exh/2.02 int. and .600 lift springs.
They have manley valves right now, but I bent 3 and am replacing them all...want to at least get the same valves, but would prefer a slight upgrade...
Also are there any others out there people would say are better than either of these?
Also...
What would be best for me? What is the differene between stock length (4.910") and +.100 (5.010") I know it means they are longer, but what difference does it make? Can I use them with my application? Are there any advantages to longer valves if I CAN use them? If I can't use them, please explain why just so I understand, and what it would take to be ABLE to...
