95 T/A fans inop!
Well, I guess unless someone else has a FIX for the issue that I'll be looking into SLP's manual swithches. It's just hard to believe that there is a failure somewhere and no fix for the failure/ issue. Is Shbox out there somewhere?
Thanks guys, I'm working on it!
-SS
-SS
Do realtime monitoring of the computer and see if the fan(s) are being commanded on. A ground is sent from the computer to the relay(s) for operation. Use a meter to see if the ground is getting there. You can follow the schematics on my Tech Page.
You can also check the operation of the w/p temp sensor while you have it hooked up for the realtime check.
Oh wow, so since this car is a 95, this could be one of those crazy gremlin, trouble-shooting jobs huh? I'm going to try and work off shbox's info and check the PCM. I thought that if you jumped 5 & 6 that did a "sanity check" and confirmed that the PCM and relays were operating correctly?
-SS
-SS
-SS
-SS
I have a similar problem. My resistance across the right fan motor is 3.1 Ohms and the left is OL (infinite resistance/no circuit). I have seen the right fan work but not the left. Does that mean my left fan motor needs to be replaced? I am getting battery power to the left fan motor.
