Help!!!! cooling probs
Old 08-06-2009, 04:32 PM
RED94Z28's Avatar
Default Help!!!! cooling probs
Well the camaro has been overheating lately and i couldnt figure it out so i took it to a shop and they said its not circulating coolant at all and heats up quick!!! What the hell could have happened? Could something have broken off causing the pump to not turn? BTW A new pump wasd put on 1 week before this garbage started happening
help guys
Old 08-06-2009, 04:43 PM
djjab57's Avatar
Its either the new pump or your radiator is clogged up
Old 08-06-2009, 04:49 PM
ss.slp.ls1's Avatar
Check your thermostat. Your pump is driven off the cam by a drive gear. There is a coupler that goes in between the drive gear that protrudes out of the timing cover and the gear in the back of the water pump. If you forget that coupler, no water will circulate. Same goes with a thermostat that is stuck closed.
See #39 here:
http://shbox.com/ci/water_pump.jpg
Old 08-06-2009, 07:32 PM
Dadic 78's Avatar
was the air bled from your cooling system after the new WP was installed? If not, you'll get crazy-fast overheating when you come across an air pocket. I'm pretty sure shoebox's website has detailed instructions on how to bleed the system of air.
Old 08-07-2009, 07:51 AM
RED94Z28's Avatar
Thanks for the responses guys.. Ill let you know when i find out what the hell is goin on..
I swear something is yrying to keep me from the track this year lol
Old 08-13-2009, 06:30 PM
adamc's Avatar
Default +1
+1 on check the coupler. It can get stripped inside. Also the tit coming off the waterpump drive gear going into the coupler can break. EWP is a good mod.
Quick Reply: Help!!!! cooling probs
