Coolant Light?
Old Aug 13, 2009 | 06:35 AM
FAST X FURIOUS's Avatar
Default Coolant Light?
I have a 1995 Camaro Z28 and for the past 2 months now the Low Coolant has been on and been figuring out why that is. So I checked the coolant in the tube and it had coolant (just briefly checked) and have yet to have time to check it in the engine. (It could be the sensor if it has coolant in it right?)
So a few days later I checked the coolant tube again and pull it out and find its not coolant its water! And the thing is the water was very, very, clear without any dirt. What's going on? Thanks guys.
Old Aug 13, 2009 | 09:40 AM
Anyone?
Old Aug 13, 2009 | 10:04 AM
the_merv's Avatar
Veteran: Air Force
Maybe you have a short in the Wire..that will cause it to stay on.
What Tube are you talking about that has water in it?
Old Aug 13, 2009 | 10:40 AM
djjab57's Avatar
The sensor is probably just dirty and need to be replaced, mine has been on for a year now. It sits on the radiator, its a little square looking box
Old Aug 13, 2009 | 02:28 PM
fleetmgr's Avatar
Someone put plain water in the car, instead of antifreeze/water mix. You can clean the sensor and/or replace it, although sometimes cleaning doesn't work and you'll still have the light.
Old Aug 13, 2009 | 02:33 PM
SexyTransAm's Avatar
unplug it and it will go away with no ses light
Old Aug 13, 2009 | 02:34 PM
ss.slp.ls1's Avatar
Old Aug 13, 2009 | 02:45 PM
monster81's Avatar
just get a new sensor, its not a big deal and easy to change,,here is the location of the sensor
http://shbox.com/1/low_coolant.jpg
Old Aug 13, 2009 | 03:25 PM
marc97taws6's Avatar
I was originally concerned myself... But mine has always been on since I've gotten the car.. it just turns on and off.. but I'm always full on coolant even in the reservoir so I kinda ignore it now
Old Aug 13, 2009 | 06:35 PM
Yeah thanks guys, it looks to be the sensor that went, time for a new one.
