cant read the pcm
With the 1995's you have to use a OBDI Cable with a OBDII Connector on it..like a few of us have mentioned.
The only way to use a OBDII Cable is if you have a OBDII Engine.
What did they do?
I think there is some issues with the ALDL wiring, i would guess that some other stuff is hanging on that wiring creating the issue. All that needs to be removed and then proceed.
1995 Cars are wierd, I haven't seen 2 that were wired the same..lol
