Car Won't Shift when Started - Right After a Clutch Change - HELP
So I did my first clutch swap recently and thanks to you guys, everything went pretty smoothly.
I fired her up today, but when I went to put the car in gear, it wasn't going to happen. I turned the car off and noticed I could shift the gears while the car is off, even without pushing the clutch in. So I shifted the car into first, started it, and I was able to drive. But as soon as I put the car back into neutral to shift into another gear, it just would not go into another gear. So here's a break down of the problem:
1. I can shift the transmission, with the car off, without even using the clutch.
2. The car will not shift once started.
3. If you shift the car into gear (while off), then start the car, you can drive in that gear.
Someone PLEASE help the newb.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
your clutch isnt disengaging completly. what clutch did you upgrade to?
try bleeding your hydraulics again.
did your new setup require you to install a spacer?
you may have also installed the clutch disc backwards
I upgraded to a Ram Powergrip. LT1's don't use shims.
The clutch disc being backwards is a possibility, but I really hope not. Would that cause this problem?
Edit - By ghetto, I mean real ghetto. I have the float like thing (that goes under the cap) like taped down to cover the hole. I've been looking for a replacement cap but NO ONE sells them. Not even the stealership.
I bled it pretty good, but I have a ghetto clutch fluid cap because I can't find my original one. So maybe that allowed air back into the system. I'll find a cap somehow, bleed it again, then post what happens. Thanks again.
If not - you'll want to listen to what others said.
Would the disc being backwards cause this problem though? That seems weird to me.
Any other things I should check? Because I'm really thinking I did bleed it right, but we'll see tomorrow for sure.
Update: I didn't have time to bleed the clutch today, but I stepped on the clutch pedal while a buddy checked for bubbles in the reservoir and we didn't see any. Wouldn't that mean the system is bled correctly?
Also, another person on a different forum said he had a similar problem which was caused by the disc being on backwards. So slayerized6 mite have been right. But does anyone have an opinion on this; would it cause this problem?
Lastly, I got the clutch fluid cap - it doesn't seem to have anything to do with the problem. I wish it would have been that simple.
Okay, so I got under there and pulled down the slave and the plastic retainer clip (that is supposed to break the first time the clutch is engaged) was still intact. This lead me to believe the slave was not fully opening up.
I also bled the clutch and there was some bubbles. After bleeding the clutch and reinstalling the slave, I am still having the same problems. I'm going to take down the slave again tomorrow to see if the retainer clip has broken yet or not. If it hasn't, it means my slave isn't opening up pretty much at all.
That's how I did it but the retainer isn't breaking.
I've talked to Ram alot during this and they haven't even mentioned an adjustable master, but I guess we'll just have to see. Once it cools down a bit I'm going to go work on it. It's 103* right now.
Aww come on I did a full 3 hours trying to get that damn 81 Vette to pass emissions. It refused no matter what but I finally found a way, left a vacuum line unplugged and she passed like it was no one's business lol.
Granted it failed 3 times before that... I kept getting close but not close enough.
Either way hope all goes well and when I swapped my tranny I did not use the zip tie method, its not too bad to deal with.
And I hate working in the heat. I don't even have cement so sweating in the dirt really sucks. I can't wait till the lift gets put in.
Ughhhhhhh.
I filled the slave with fluid and reinstalled it. I heard the straps break, so it's getting pressure now. But I'm still having more or less the same problem.
1. I can still shift with the car off and not having to press the clutch, but no longer into reverse (I used to be able to shift into any gear).
2. I still can't shift when it's started, except for into first (used to not be able to shift into any gears). But even when putting it into first, it takes some force.
