Guideplates GMPP or Comp or what
Old Aug 12, 2009 | 07:40 PM
gregrob's Avatar
Default Guideplates GMPP or Comp or what
I already have a set of GMPP guideplates but I've heard talk that they are not hardened and I should consider another set.
What about the comp ones here http://www.jegs.com/i/Comp-Cams/249/4808-1/10002/-1
If those aren't any good can someone point me in the direction of some that you have had good luck with.
I've heard of trickflow hardened ones or Isky adjustables being good.
Old Aug 12, 2009 | 07:42 PM
z_speedfreak's Avatar
I would harden them instead of spending more $$
Old Aug 12, 2009 | 07:49 PM
gregrob's Avatar
how would I do that
Old Aug 12, 2009 | 08:03 PM
take a torch to them until they are red hot and then quench them in water but be careful to heat them evenly so you don't make any thin weak spots. its not to difficult at all tho, maybe practice on some scrap metal if you have never done it before, don't go too hot and do it evenly and you'll be fine.
Old Aug 12, 2009 | 08:13 PM
ss.slp.ls1's Avatar
I use trickflow guideplates, not sure if they are hardened or not.
Old Aug 12, 2009 | 08:15 PM
SPRAYED Z's Avatar
I use the tfs as well
Old Aug 12, 2009 | 08:18 PM
robsquikz28's Avatar
Tfs or C.C are the only ones I recommend putting on
Old Aug 12, 2009 | 08:41 PM
gregrob's Avatar
I've heard the comp plates may have a slight alignment issue. Has anyone experienced that?
Old Aug 12, 2009 | 09:26 PM
shbox's Avatar
Yes, lots of people.
You can take a file to the GM plates to see if they are hardened.
Old Aug 12, 2009 | 10:56 PM
TRANSAM GT4's Avatar
Im running GMPP guide plates with no issues.
Old Aug 12, 2009 | 11:08 PM
BALLSS's Avatar
My experience with GM plates is they are not hardened. Wear quickly followed.
I have the ISKY "adjustables" work great
Old Aug 13, 2009 | 12:10 AM
Tapout911's Avatar
+1 for the Isky adjustables. No alignment issues with them. Ive tried both the others and didnt like the alignment
Old Aug 13, 2009 | 12:24 AM
Elliott's94Z's Avatar
Trickflows as well
Old Aug 13, 2009 | 01:09 AM
skinnies's Avatar
I ran the manleys without a problem, don't run the comp ones.
Old Aug 13, 2009 | 01:27 AM
BizZzatch350's Avatar
Moderator
I'm running GMPP guide plates in my car, they were a ton better then ones I got with the Darts.
Old Aug 13, 2009 | 02:59 AM
gregrob's Avatar
How do you do this Rob, what do I look for when I file it. Just how soft the metal is or what?
and can anyone link me to the Isky's?
Old Aug 13, 2009 | 09:04 AM
shbox's Avatar
Choose an inconsequential place on the plate and take the edge of a sharp file and see if it digs into the metal. It will want to glance off more, than dig in, if it is hardened (on normal metal, the file is going to dig right in). Check every one as some have gotten mixed batches.
Old Aug 13, 2009 | 09:13 AM
gregrob's Avatar
I'll try that, thanks.
Old Aug 13, 2009 | 11:40 AM
AChotrod's Avatar
modded TFS GPs here
Old Aug 13, 2009 | 11:59 AM
Bersaglieri's Avatar
Isky adjustable.
-Dustin-
