WTF Is my Problem?!?!
Old Aug 20, 2009 | 07:17 PM
SoxXpupPeT's Avatar
Exclamation WTF Is my Problem?!?!
ok afew weeks ago i noticed that under high rpms for awhile and i give it the gas it would bog down and backfire abit. i thought it was low fuel psi being that i have a tune on my cammed lt1 and a stock 167k mile pump/fuel regulator/ and injectors. so i changed out my fuel pump with a walboro 255 and it Still did the same thing. ok i said, its the FPR. so i changed that out just now and it still does the same thing! im trying to find a fuel pressure guage to hook up to the rail and check it there. the symptoms of it now is very long starts and a rough idle at times. and whenever i get over 3k or so with any kind of gas it bogs down and loses all of its power. i fear its my optispark. is there anyway to check that ? i really need suggestions the cars my D and i cant waste time trying to fix it.
Old Aug 20, 2009 | 07:27 PM
AChotrod's Avatar
Rotor could be loose
here is how to check the opti but Im not sure if it will work since the car still runs?
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Aug 20, 2009 | 07:48 PM
ss.slp.ls1's Avatar
Testing the fuel pressure under load at WOT will eliminate a fuel pressure issue.
It could be anything in your ignition system...plugs/wires/coil/opti.
Any codes?
Old Aug 20, 2009 | 08:31 PM
SoxXpupPeT's Avatar
i cant even get the car to WOT it completely ***** up. i dont have a scanner nor knows anyone with one. im going to say its ignition related because my friend had reminded me about arcing and sure enough. i have afew wires that are arcing! not alot but enough to see it. that and my accel coil is doing abit of a light show. i feel so stupid for not checking that sooner. im going to buy msd everything tonight and hopefully have it all set up next week. ill keep it updated
Old Aug 20, 2009 | 09:31 PM
AChotrod's Avatar
well seems you figured it out! Let us know!
