is this repairable? what caused it? and how much to repair it?
Upon tear down i found both cylinder heads cracked in the center bolt hole to the center water jacket. do you think a machine shop can weld and resurface these? what would it cost?
![](http://i28.photobucket.com/albums/c214/gregchevymsd/IMG_5216.jpg)
![](http://i28.photobucket.com/albums/c214/gregchevymsd/IMG_5215.jpg)
Lloyd told me thats a common problem, he sees lots of heads cracked like that and he can fix them / have them fixed.
Buying a known-good used set would be ok, but you run the risk of buying a set cracked just like yours if you're not careful.
I would have mine fixed if I had that issue, but I like keeping as many parts as I can original to the car.
what would you guys do???
i just got the heads back, they put a steel sleeve in the center bolt hole, decked and pressure tested the head... i take one look and they are still cracked!!! they wanted $250 for their repair work... i sent them back and told them i was over charged for work i did not request. i feel that if they weld the crack, deck the heads again, the compression will be to high to use or have built down the road. should i ask for a stock set of heads and pay 1/2 the labor they f'ed my heads up with... im pretty upset right now to say the least.
its not in a street car and it runs at +3000 feet elevation, wot for 200-500 miles at a time.
like this...
http://www.vimeo.com/4348097
like this...
