How much is my engine worth?
I will sell it complete all the way to the headers, waterpump, ecm, harness etc.
For those of you who dont know what it is:
4 bolt vette block 383
Eagle 4340 rotating assembly
Forged flat top pistons, Mahle rings(can spray if wanted)
Half filled block, zero decked
1 7/8 Hedman headers modded to work with a/c, jet hot 2000 coated
CSi electric water pump
Comp solid roller 254/254@.050......670/650 lift 108 LSA
Comp endurex pressurized lifters
Comp pushrods
RHS 235 heads converted to work on a LT1, flow 319@.700
DRE shaft rockers
Canton pan
Melling pump
Super vic intake, billet rails, 42lb injectors
Aarons sheetmetal elbow with monoblade TB
ATI balancer
SFI flywheel
LT4 starter
Engine is fresh, less than 1000 miles. This is a STREET engine, runs on 93 pumpgas. Has 6000 miles total on it. Has ALOT left in it. In a 3000lb car with the correct converter could possibly get into the 9's all motor with the tune tweaked. I get up on the interstate and drive 70 miles to and from cruise ins with it, recently drove 60 miles to the track, made 4 passes pulled the tops out cruised the beach in south Ms and drove 60 miles home.
Just curious, all input welcome.
In a 3600lb car with a tight converter it ran 10.58@126. WIth GM opti and GM ecm.
Look how long it took to sell tony shepards and Z8's old top ends...both were STEALS on some of the best parts around and they still had to sit on them for a while.
I would say its "worth" around 9 grand, but sadly I don't think you could get someone to bite for more then ~6500
. Trending Topics
--Alan
--Alan
Oh well, guess its time for some more portwork, more cam, BS3 and 4L80E aint it?
I have easily 15 grand in the motor and if sold i'd like to get 10K.... but I doubt i get it even if the motor was to hold the world record at some point....
it sucks but cars and engines are THE single worst investment ever....
engine short-$2500-3k
headers-$350
heads and intake-$2000
cam-$250
water pump-$175
oil pan $200
balancer, pulley, flywheel $350
injectors-$200
Thats just a little parts list and going rate on parts that would be over 6k right there!
1. dont matter what excuse full wt. pump gas ect. all that matters is 10.60's
2. I can find complete 555 running 9.0 in the same wt car on stock suspension for 9k.
Im not knocking you just being realistic. You would be lucky to get over 4500 for it..... now maybe you find someone with money on ls1tech or something they might buy it. For a aftermarket head flowing that it should run 9's Now I ike he coment of what it should do in a 3k car..... but it hasent, so its a horrible selling point. I know what it can do, but it hasen't so its hard to sell iut that way.
Im not bashing you dave, I tried to sell mine for 4500 complete carb to oil pan and got no offers and I have been faster on a stock head with stock valves.....there is no market for it
