LE1.5 cam LE2 Head track results
Old 09-02-2009, 01:05 PM
86formula's Avatar
Originally Posted by 95ztrey
NICE , whats your DA , i have an le2 cam and le1 heads with full bolt ons and have only gone 12.48 at 112 here with 6750 DA amarillo tx
-440 lastnight were 31ft above sea lvl. You should be faster with a 112 trap speed. It's not uncommon to see -2000 DA here
Old 09-02-2009, 01:07 PM
95ztrey's Avatar
HOLY CRAP thats so much better than here ..... my car should trap 115-117 at sea level i hope
Old 09-02-2009, 03:56 PM
1redta's Avatar
my bauer cam (read speed-demon24's thread)finally killed my springs at around 5000 miles going to switch to the golds and try some link bar morels to help, my spider gave up the ghost!
Old 09-02-2009, 04:28 PM
86formula's Avatar
They are whT Lloyd reccomended and I haven't had any valve float issuse spinnning to 6200-6500
Old 09-02-2009, 04:36 PM
FASTFATBOY's Avatar
<<<<<<<<<<<Waiting for the Ai guys to flood the thread saying this isnt possible.
6000 rpm launch...THATS A MAN!!!!!!!!!
Good job man, some DA rears will make a world of difference.
Thats enough MPH for 11.40's
6k launch on some short tires with a 4.30 will kick you in the pants if it'll stick.
Old 09-02-2009, 05:20 PM
James Montigny's Avatar
Nice work man
Old 09-02-2009, 06:05 PM
86formula's Avatar
the best part is that i wasnt even track prepped, i even had my back seats in lol
Old 09-02-2009, 08:44 PM
flyinZ's Avatar
Congrats!
Old 09-03-2009, 06:59 AM
wrd1972's Avatar
OP. What clutch are you running?
Old 09-03-2009, 07:12 AM
86formula's Avatar
A custom built JSPerformance drag racing clutch Www.JSspeedandcustom.com
Old 09-03-2009, 01:21 PM
strokin93z's Avatar
Very nice results. Good Job. I hope to hit about the same times..
Old 09-03-2009, 03:16 PM
  #32
C_Rules's Avatar
awesome nice times. always like to see wen the lt1s break into the 11s as thats what im aiming for next time out.
i know you changed your opti but were you driving the car with the rotor screw which had fallen out prior to the change?
Old 09-03-2009, 04:30 PM
  #33
86formula's Avatar
Yeah I went 12.65 with one screw hanging on lol, I couldn't tell at idle be it's a lopey cam but it dis smooth out a little with the new opti. It gave me a
mean vibration at 2k rpms too
Old 09-03-2009, 10:49 PM
  #34
86formula's Avatar
11.89 @ 116.14 1.70 60' tonight. air was worse and i took the seats out
Old 09-04-2009, 12:46 AM
  #35
speed_demon24's Avatar
Saying what isn't possible?
Old 09-04-2009, 09:26 AM
  #36
C_Rules's Avatar
so you had no idea that the opti was acting up until you took it out and opened it up? once it was changed you gained over .5 a second? just curious as this could be one thing to look at if my car doesnt run right.
Old 09-04-2009, 10:29 AM
  #37
Moderator
BizZzatch350's Avatar
Great times
Old 09-04-2009, 11:14 AM
  #38
86formula's Avatar
Yeah, I mean at idle it's really hard to tell because the idle is supposed to be rough with the cam but I had a miss from 5k rpms and up and was only trapping 109 with the opti how it was
Old 09-04-2009, 11:54 AM
  #39
C_Rules's Avatar
hmmmm....sounds very familiar to my trap speed which is way too low for my setup. i dont have any misses in the high rpm range though unless i just can't tell.
Old 09-04-2009, 03:31 PM
  #40
Z-RATED94's Avatar
Very nice, and I'm sure you'll knock off quite a bit more with the new gears. Lets not talk about negative DA any more though, ok? It's a little depressing for the rest of us that never get to see such a thing.
Quick Reply: LE1.5 cam LE2 Head track results
