SLP or shbox
a car going 80-85 while the speedo says 55?
i tried changing the speed sensors from the 95 to the 93 transmission and no change. i have narrowed it down to either the gauge cluster is screwed up or the guages being different.
You need to tune it to have it corrected
The reason the Speedo is off is cause the T56 reads a 17 Pulse Reluctor Wheel, you will need the PCM adjusted for that. It's easier than converting anything inside the T56.
