Time for a new short block.
Old Sep 5, 2009 | 09:49 AM
SpeedDensityZ's Avatar
Default Time for a new short block.
Well my bottom end let go. From what I can tell it broke the crank. I was at the track and it broke at about 6000rpm in third gear. The only parts found on the track was the oil filter, oil sending unit, and a freeze plug. It bent that nice AI cam and bent both the valves on the #8 cylinder. Every exhaust valve hit every piston. It actually cracked the timing cover up the middle and broke the cam plate in half. It was a budget bottom end. It had an Eagle cast crank, SIR Rods and Speed Pro power forged pistons. I don't blame the manufacture, I was making more power and spinning it over what it was capable of. I'm going to do the same setup exepct with stronger parts this time so I can spray it. Looks like it will be down about a year. Here are some pictures enjoy!
Old Sep 5, 2009 | 09:55 AM
fergymoto's Avatar
My cast Eagle crank broke in the EXACT same place as yours. **** that junk.
You got one hell of a souvenir right there.
Old Sep 5, 2009 | 10:02 AM
I know that's the truth!!
Old Sep 5, 2009 | 10:13 AM
duh's Avatar
duh
Impressive......good excuse to spend some money though
Old Sep 5, 2009 | 10:18 AM
ThreeHonks's Avatar
that block looks repairable
Old Sep 5, 2009 | 10:25 AM
AChotrod's Avatar
JB weld!!!!
Old Sep 5, 2009 | 10:38 AM
LOL!!
Originally Posted by AChotrod
JB weld!!!!
All of us LT1 guys think the same.. LOL
Old Sep 5, 2009 | 10:40 AM
86formula's Avatar
wow i hope when it happens to mine i do it right like you did lol
Old Sep 5, 2009 | 10:42 AM
AChotrod's Avatar
If you need to get it back on the street I have a couple tubes I could loan you!!!
Seriously thats a major Bummer!!! Thank god Short blocks are easy to come by cheap!
Old Sep 5, 2009 | 06:11 PM
harner's Avatar
This makes me think twice about the Eagle cast cranks I was looking into!
Old Sep 5, 2009 | 06:15 PM
RamAir95TA's Avatar
+2.
So did mine.
You say you aren't going to blame it on the manufacturer? **** I would! Eagle cast cranks are garbage. You, ferg, myself, and countless other people are a testament to how poor their cast parts are.
Old Sep 5, 2009 | 06:28 PM
lordrazo's Avatar
damn you should have just stayed with the stock one and played your luck what crap good luck on the next build
Old Sep 5, 2009 | 06:48 PM
Tireburnin's Avatar
Damn that was an expensive mishap. It's a shame it broke all of your nice parts too.
Good luck getting it back together.
Old Sep 5, 2009 | 07:19 PM
fergymoto's Avatar
Joe, I hope you aren't referring to the crank in your new motor! Are you?
Old Sep 5, 2009 | 09:08 PM
Black94Z28's Avatar
eagle cranks are garbage...believe they are made in china FWIW
Old Sep 5, 2009 | 10:07 PM
Matts94Z28's Avatar
WOW!! You owned that block and everything inside of it!
Old Sep 6, 2009 | 02:06 AM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
welp looks like we are in the same spot.
snapped right after the number one journal. i think ******* eagle is not sooo good. i will never buy another product from eagle. scat crank for me!!!
Old Sep 6, 2009 | 02:27 AM
madhatter's Avatar
Now thats the catastrophic damage I like to see!
Shitty to hear, but now it is a reason to go bigger and better.
Old Sep 6, 2009 | 04:32 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
It is not the fact that it is an Eagle crank. It is the fact that it is a cast crank. Show me a forged steel crank that has done that on an NA LT1.
Old Sep 6, 2009 | 07:15 AM
now i know this is gonna start alot of **** but i was told by my engine put togetherer. that its was a steel crank. SO I WAS TOLD........................
