Solid roller set up lt1
There are lots of advantages to going solid roller, they build alot more power than a hydraulic cams, and theres alot more options, but you need all of the supporting mods for a solid roller, you also need to get rid of the knock sensor if you plan on running the stock PCM. More people will chime in with more advantages and disadvantages.
It really depends on your build, hydraulic may be better suited for a mild build.
Something people often forget is that S/R setups do not like low RPM,
a lack of oil can lead to heat-related problems in the valvetrain.
Discuss the complete package with your cam vendor.
Can you drive it on the street? Sure you can.
Is the optimal solution for most street/strip cars? Not really.
Mike
What I was told and live by is if building a SR for the street you must not skimp on the lifters. As already stated there are lifters out there that can support low rpm usage w/ a solid roller with no issues. You may loose a bit of overall oil pressure because of the extra oiling ports the lifters have, but that can be solved by using a set of oil restricting pushrods.
I wouldn't have my setup any other way than how it is now. I adjust valves every oil change just because...
solid roller springs with at least 240 lbs.@ the seat/540 lbs. open( depending the aggresiveness of the cam)
solid roller lifters (.300" tall for our LT1 block)
.080" wall push rods
strong reliable rocker arms,ie.Comp pro magnum
