LT1 Rotating Assembly Questions
1. Are there any setups I should avoid?
2. Will most if not all 1 pc. rear main setups work for SBC in an LT1?
3. Not looking for ridiculous power so I am open as to cast versus forged on the crank. Obviously would like forged, but if I am only making 400 - 450HP after the setup, I think, from my readings on here, a cast crank would be OK, yes?
4.Regardless of cast/forged crank, a good set of forged rods and pistons might be best. Should I be concerned with H-beam versus I-beam rods?
Please ask any questions so I can get the best answer possible. Thanks again, everyone!
2.) Any 1 pc. rear main SBC crankshaft/piston/CR will work.
3.) IMO, if you're using anything other than the stock crankshaft, go with a forged piece. The rotating assembly should be able to handle 150% as much as you plan to throw at it for reliability's sake.
4.) H-beams are always nice, but not a necessity at your desired power level. I'm using Scat forged I-beams. Definitely go with a forged piston mated to a 6" rod.
I would like to keep the build under $7K. I guess my questions now would be:
1. Can I buy a rotating assembly without knowing the full specs of the heads I am using? In other words, can I get the heads milled appropriately to achieve the compression ratio I want based on the piston specs?
2. I saw someone posted on here they had a 383 with 5.7" rods. I thought 383's were a 400 crank with 6" rods?
3. Is 12:1 compression reasonable on pump gas given a good dynotune? If I wanted more umph afterwards, could I give it a small shot of N2O or a small supercharger < 6lbs? (I know the SC would blow the 7K buildout of the water)
Sorry I seem a little lost in all this now.
Last edited by afterburner82; Sep 11, 2009 at 08:19 PM. Reason: One additonal comment.
Forged Ohio crankshaft
Forged Scat I-beam 6" rods
Forged SRP -5cc pistons
Decked block, zero deck height
4-bolt main (2-bolt would be fine as well)
AI 200cc heads/cam package (52cc chambers)
.026" head gaskets
This results in a SCR of 12.4:1 (DCR of 9.1:1). I run a mail-order tune from PCMforless (no dyno-tuning yet). Haven't been to the dyno just yet, but it runs what it does with no KR.
If you have all forged components, spray away! Remember, nitrous loves compression. I plan on a 200+ shot in the near future.
My engine ended up being around $8500, somewhere around there.
.026" head gaskets
Did you have to do any clearancing for valves?
Static compression is just that, a static figure, and has no bearing on engine performance (dynamic compression is the more important figure). On a good tune, running 9.1:1 DCR on 93 octane is easily doable.
6" rods offer too many advantages over their 5.7" counterparts when set up and clearanced correctly, IMO.
.026" head gaskets
http://www.eaglerod.com/index.php?op...d=34&Itemid=41
I make a little under 400rwhp through an auto with no problems. not exactly a RA I'd trust to high rpm or nitrous though especially with the eagle balance in it. my setup stops making power around 6k rpm so this isn't an issue for me.
I kinda wish I would've went forged with a good balance so I could bottle it and rev it higher without worry, but this was my first motor build that I'd ever put together and I wasn't about to put a $2k+ rotating assembly in a motor I wasn't even sure would last. so oh well live and learn but I had no idea I'd do everything right
