nitrous is done and testing this week
Old Sep 16, 2009 | 03:53 PM
  #41
Racin96ss's Avatar
Are you running 2 ECUs w/ one for the spray?
Old Sep 16, 2009 | 03:55 PM
  #42
LS1 SPEED's Avatar
no..little hard to swap being under the dash. Jim is writing me 2 files for the car.
Old Sep 16, 2009 | 05:29 PM
  #43
LS1 SPEED's Avatar
The car is on the dyno tweaking the NA tune. The reason being my hotwire kit burned out as mentioned before and I am only running 1 pump now. The amount of fuel volumn did alter the way the car ran. I always had a cold start issue and had to throttle the car for a few seconds and now that is gone...reach in and turn the key and it idles great. The A/F was a little leaner on 1 pump v's the 2, so we are just playing with the A/F some.
I'm super happy with the combo since it just made over 460 rwhp
Old Sep 16, 2009 | 06:28 PM
  #44
FASTFATBOY's Avatar
Locked or unlocked?
Old Sep 16, 2009 | 07:02 PM
  #45
LS1 SPEED's Avatar
runs were done locked
NA
462/431
N20
525/512
nitrous graph looks a little odd due to the converter flashing then locking,unlocking and then locking again
yeh I know it's not the best to do, but I trust my Yank/FLT combo
We ran a real safe tune to just make sure it's working and did not pull it past 6600.
20-21 degrees of timing
11.3-11.5 A/F
116 in the dedicated
93/100 in the fuel tank
I will work on the nitrous tune at the track to get it in the 12.0-12.2 area.
Old Sep 16, 2009 | 07:50 PM
  #46
C_Rules's Avatar
how much of a hp loss is usually seen when running with the converter unlocked?
Old Sep 16, 2009 | 08:19 PM
  #47
LS1 SPEED's Avatar
unlocked was about 20 rwhp if I recall when the car was first put together
little more info :
62/46 with 11psi v's the 10psi recommended which is the reason it's rich
950 bottle pressure
I discovered when purging the system down after closing the bottle it did not look clean. Then after taking my bottle out ( which was over 1 year old ) it was damn near out of spray and seems to have air.
bottle is getting fully emptied and filled tomorrow for testing Fri
I know the #'s are low on spray, but I was not really looking for a # and rather the A/F being o.k to start with.
Old Sep 17, 2009 | 10:31 AM
  #48
AChotrod's Avatar
Damn those NA numbers are impressive!!! Was that N20 dyno just the 100 shot?
Old Sep 17, 2009 | 10:45 AM
  #49
LS1 SPEED's Avatar
thanks Mike
it was the 150 shot, but as mentioned above the tune is very conservative and A/F rich. I was not looking for big #'s on the bottle, but to just wanted to check the A/F to be o.k to start tuning at the track.
+ I just weighed the bottle after removing it and it's is just about empty w/ 3#'s. This could not help and seems to be some air as well.
I will work on the tune at the track for the N20 tomorrow.
Old Sep 17, 2009 | 10:53 AM
  #50
AChotrod's Avatar
3# of air deffinitly wasnt helpin. lol! See ya in the morning and hope to see ya at the track tomorrow night and watch that beast get down!
Old Sep 17, 2009 | 11:00 AM
  #51
LS1 SPEED's Avatar
I'm not saying all air, but it does appear to be some air in the bottle when purged and or opening the valve.
I will not be in tomorrow, so the guys will take care of you @ 9a.m. There better be a red Formula at the track tomorrow testing with the new combo and good air.
Old Sep 17, 2009 | 11:07 AM
  #52
AChotrod's Avatar
If things go well on the dyno it will be there!!!!
PS,I was JK about 3# air
Old Sep 17, 2009 | 11:10 AM
  #53
LS1 SPEED's Avatar
good and gooder
Old Sep 17, 2009 | 11:12 AM
  #54
Racin96ss's Avatar
Engine seems to be loosing up nicely
Looks like I need to start thinking about a fuel cell soon too.
GL tomorrow, looks like the weather will be perfect for getting some nice runs in.
Old Sep 17, 2009 | 11:17 AM
  #55
LS1 SPEED's Avatar
YEP..seems to like the dyno
I will post results Sat. good or bad.
Old Sep 17, 2009 | 11:57 AM
  #56
Racin96ss's Avatar
And the track
Old Sep 17, 2009 | 11:59 AM
  #57
LS1 SPEED's Avatar
yes..it does run a # as well.
Old Sep 19, 2009 | 10:58 AM
  #58
AChotrod's Avatar
Sorry couldnt make it out. What happened? How did it run?
Old Sep 20, 2009 | 08:57 AM
  #59
LS1 SPEED's Avatar
sorry to see you not make it...the track was there, but the air could have been better
NA 10.86@123 1.41 60 ft
N20
I want to work some more on getting the most from the 150 shot both traction and tune wise and move from there.
I did not go over the plugs Fri, but got the A/F in the 11.8-12.2 area and I was very happy with the results for the 1st time out
1.36 60 ft ..still more in it
6.40 1/8
107 mph 1/8
10.09 ET
132.5 1/4 MPH
I plan to put a little more timing in it, play with shift points and keep working on the window switch to get it to 60ft harder...went 1.41 on HP the same night.
I was a little worried this night so I tightened things up after Z8s put his LS1 street car on the bumper. I drove the car to and from the track and wanted to make sure I could make it back the 1.5+ hr trip.
I have to getting a alternator issue sorted out here and be back at the track in a couple weeks.
Old Sep 20, 2009 | 09:18 AM
  #60
FASTFATBOY's Avatar
SWEET!!!!!!!!!!!!
Funny, my alternator dumped on me yesterday 50 miles from home and no one had one. When the battery voltage gets low the trans and car do strange things LOL.
SUCKED.
