Really Stupid Question
Thanks
Hold the brake, drop gear to neutral (this allows you to further clamp the brakes) and press down on the accelerator past 1800 RPM (stock RPM stall) The tires will begin to spin, push it more for more tire spin and more smoke. Avoid hitting high RPM, keeping it around 2000-3000 should be enough.
It doesn't put too much of a strain on the brakes as much as the rear. Don't go crazy, but once in a while a burnout is nice and healthy for your F-Body
With a stick you turn your right foot sideways and use it to hold the brake and gas it, get the rpm's up a little and let out on the clutch, keep the brakes down and shift when needed.
P.S. don't tell your dad we told you.
Thanks
