What shoud I do next??????
Drag shocks
N2o
lower a-arms
drag brakes
front bumper support(so i can remove the stock supports)
Shift light
line lock
roll bar
etc. etc. etc.
or anything else you can think of and whats the order you would do this in?
shocks.. I suggest Strange double adjustables for the front and simple Comp Engineering rears
rear sway bar.. I suggest UMI's new drag bar
a-arms will drop a little weight, but its a big expense for little gains IMO
shift light is a great idea being a 6 speed car
6pt rollbar especially if you plan to keep hitting GLD
linelock for a 6 speed is a good idea as well
Shift light, drag shocks,line lock,ditch the 10 bolt if u haven't did it already!
lastly any weight you can remove would help.
I Like Larry/Fergy's plan cause Im gonna need it all anyways and I dont want some half *** kit. I want something like Larry's
Wich is big bucks.You guys think the UMI drag bar is ok for the street. My stock Sway bar looks so whimpy back there! Damn thats another thing I want!
I was in a hurry to get nitrous back on the car but now that I am leaning more towards finishing off my suspension (which all I need is front tubular A Arms) and doing a roll cage. I want to go as fast as I can with a fully suspended street car on the new 383 and then spray the 200 hit. LOL
So sad my 13 second car has a roll bar, a lot of people see that and think its fast. I just tell them I go corner carving with this thing, and will probably see more chances of a roll over than at a dragstrip.
someone please correct me if im wrong
http://www.ws6project.com/user_stor/...roducts_id=656
I'm sure there are many different brands on the market but I like this one because its small and easy to install and adjust. I got the one that has the launch feature, it works good for launching on the street at consistent RPMs but I don't use at the track.
Car is not a drag car so I want to be able to adjust it for decent street handling when I need to, so the DA's if I am absorbing things right would be possible to do so.
