new track times .... again
Like I said it's not an uncommon problem, for a 4L60 to bump the limiter on the 2-3 shift. Especially with a stall or anything that allows the motor to turn up faster (like a nitrous kit would). There is just more **** that has to happen in the transmission on that shift, so it will always take longer.
You can try lowering the commanded shift RPM, raising the trans pressure (electronically or mechanically), raising the limiter or all of the above. Either way you don't need to be hitting the limiter on the spray.
