383 Machine Work
Old Sep 19, 2009 | 05:41 PM
22lambo's Avatar
Default 383 Machine Work
So I am going to make my LT1 a forged 383 stroker. However, what need's to be done to the block in order to accommodate the stroker? And how much would I be looking at? Also what are some good places that can do it? Thanks.
Old Sep 19, 2009 | 05:47 PM
madmike9396's Avatar
advanced inductions is a good place to look
Old Sep 19, 2009 | 05:56 PM
22lambo's Avatar
Do they do machine work? Also is this kit any good?
The "Kit #SBC5 SBC 4340 Rotating Assemblies" one
Old Sep 20, 2009 | 09:41 AM
Corey @ Clayton Racing's Avatar
Deck, Aline hone mains, bore and hone cylinders. Should be done on ANY good build. You will also need to have the block clearanced for the rod bolts because of the extra stroke.
Old Sep 20, 2009 | 10:48 AM
myltwon's Avatar
also the oil pan needs to be clearanced
Old Sep 20, 2009 | 11:06 AM
depends on the oil pan, and rods.
Old Sep 20, 2009 | 12:17 PM
22lambo's Avatar
Thanks guys for the info! Do you know how much a shop would usually charge for that? Just a ballpark estimate.
Old Sep 20, 2009 | 12:36 PM
700-800 in machining labor. We sell fully machined and clearanced blocks with ARP studs ready for assembly for about $1000
Old Sep 20, 2009 | 12:39 PM
22lambo's Avatar
Thanks! We got a long block for super cheap so we will get that machined.
Old Sep 20, 2009 | 10:42 PM
myltwon's Avatar
well dependant on if you want to keep a stock pan or go to a more stroker-friendly one. even with i beams on my 383 with "stroker" ARP bolts I still had to clearance the oil pan some. the pan rail is the area that is questionable mostly as I didn't have to but others with beefier rods or larger crank throws had to.
Old Sep 20, 2009 | 11:10 PM
James Montigny's Avatar
$35.00 Jet Clean Block
$45.00 Boil Block
$51.48 Cam bearings (installed)
$39.83 Freeze plugs (installed)
$120.00 Deck Block
$175.00 0.030" overbore w/plate
$74.99 Main Bearings (installed)
$150.00 Balance Rotating Assembly
$55.00 Weld Block (if/when you break into the waterjacket)
Old Sep 20, 2009 | 11:14 PM
22lambo's Avatar
$45.00 Boil Block
$120.00 Deck Block
Oh wow thanks! That gives me a much better idea So where did you get these prices? Could I get my block done there?
Old Sep 20, 2009 | 11:21 PM
Any local Machine shop could do it but i would make sure they have a good name first
Old Sep 20, 2009 | 11:35 PM
22lambo's Avatar
Alright, I'll do my research. Thanks guys. Oh ya, so can I go to the machine shop and ask them to the work for a 383 or do I have to tell them every thing what to do?
Old Sep 21, 2009 | 12:19 AM
Just tell them what u want, Just ask them do they ever mess with lt1 blocks and lt1 stuff thats what i do, If they dont do lt1s get the hell out if they have done them just tell them what your plans are and go from there. Good luck with ur build
Old Sep 21, 2009 | 08:45 AM
myltwon's Avatar
I think it cost me around $450 or so for all my machine work
-deck
-bore
-hone
-hot tank
-cam bearings
-freeze plugs
I did the 383 clearancing myself, it's not hard but then again I had probably the most clearancing friendly kit of all
Old Sep 21, 2009 | 08:57 AM
make sure you have the mains aline honed or you will kick yourself in the *** later... Also to make sure that everything is clearanced correctly you want them to have your rotating assembly in hand, to physically test fit and check the rod bolt to block clearance.
Old Sep 21, 2009 | 09:12 AM
22lambo's Avatar
Will do. Thanks for all the great help!
Old Sep 21, 2009 | 09:20 AM
408StrokerSS's Avatar
Something to think about also with any lt1 stroker is to have the block tapped for some 4blt splayed main caps. Its about 400 extra dollars but good insurance.
Old Sep 21, 2009 | 09:23 AM
22lambo's Avatar
What is that for?
