panhard bar adjustment
So when i lowered my car i didnt research enough as usual. My rear suspension geometry is now f-ed. Im ordering an adjustable panhard bar to correct it. how would i go about adjusting the panhard bar leangth for optimal rear suspension geometry?
If you are running wide rear tires you may need to check your inner fender clearance as well. My car is not very "true" as when the rear is centered between the outer fenders it will nearly rub the inner fender on one side. I had to go a happy medium between centering the rear end between the inner and outer fenders. Did you get an on-car adjustable panhard bar?
i havnt ordered one yet i was looking at the hotchkins adjustable one on jegs
http://www.jegs.com/i/Hotchkis/515/1...oductId=757226
