This cam?
Old Sep 24, 2009 | 12:17 AM
ebeard's Avatar
Default This cam?
Alright I came across this cam on craigslist. http://www.compcams.com/Cam_Specs/Ca...csid=1107&sb=2 I am going to be rebuilding my lt1 around christmas ( weak cylinder and bad opti ) I most likely won't have the money for heads or port work at that time. I could pick this up pretty cheap and i just thought i would see what you guys thought. i have exhaust and i could get it tuned afterwards, injectors if i needed them.. It looked pretty mild to me. Would it be a good cam to run for awhile until i open the motor back up again? would it add a little usable power or just topend i couldn't use? My long term plans is an LE set up. Just thought a cheap cam would make it a little more fun for awhile.
Oh also since i need to go cheap i would probly reuse most of the valvetrain. except maybe the pushrods if i needed a different length. I'm not an engine builder. Just a first time assembler. Thanks in advance for the info
Old Sep 24, 2009 | 12:19 AM
hitmanws6's Avatar
that is far from a mild cam. thats the CC503. its regarded as the biggest cam to use on stock heads
Old Sep 24, 2009 | 01:24 AM
ebeard's Avatar
i saw that it had the same duration as the cc503 but the lift is different. or maybe i'm reading it wrong. Compare the specs between the comp site and the lt1 valvtrain write up https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Old Sep 24, 2009 | 02:46 AM
hitmanws6's Avatar
the comp site lists the lift using 1.5 (stock) rockers. the specs in the sticky are with 1.6 rockers.
Old Sep 24, 2009 | 03:08 AM
knight17Z's Avatar
Do it need new springs tho....
Old Sep 24, 2009 | 08:56 AM
myltwon's Avatar
cc503 is an awesome cam with stock heads
I loved mine
Old Sep 24, 2009 | 10:04 AM
StealthFormula's Avatar
That's a fantastic cam to run. I ran that for a while before I could afford to do my LE2 setup. The cc503 picked up something like 6-7mph for me in the quarter. I felt a strong increase of power in the mid-range and top-end without a loss down low. It's IMO the best all around cam for a stock headed/stock bottom end setup.
I actually DD'd the car with that cam an hour each way to school for awhile and it was great. Anymore cam would be too much for that IMO. If your Auto just make sure you have a large enough stall converter.
BTW: Valve Springs are required, I would suggest the Crane 10308-1, they are cheap and will work fine. If your motor was never opened up before then stock 7.200" pushrods will do the trick.
Old Sep 24, 2009 | 01:19 PM
am_muscl's Avatar
i can tell you personally, i'm running a cam similar to the 847, on stock heads/bottom end, and it runs pretty strong. But one thing you do NOT want to cheap out on is the valvetrain products. it is absolutely necessary to get new springs, valve seals, and locks, and probably roller rockers. but again thats just my opinion
Old Sep 24, 2009 | 01:46 PM
ebeard's Avatar
Ok thanks for the info guys. If i had realized this was the cc503 i woulda already bought it lol. Lets hope he still has it. So i should get new pushrods and springs and valve seals? I am not framiliar with valve seals. What do they look like? where are they?
Old Sep 24, 2009 | 05:22 PM
Sk8phreak88's Avatar
They slip down the top of the valve. The springs will go over them when you install them. They are cheap, and a good maintenance thing to do, especially since you'll have the motor apart that far anyways.
Old Sep 24, 2009 | 06:32 PM
ebeard's Avatar
Alright thanks. Well picked up the cam today. Going in over Christmas break!
Old Sep 24, 2009 | 07:14 PM
ebeard's Avatar
Also is the cam going to max out my stock injectors?
Old Sep 24, 2009 | 09:23 PM
myltwon's Avatar
might be running on the higher end of the DC with stock 24's but you should be alright as long as you have a good tuner. if you do decide to upgrade some 30# SVOs or something slightly larger should do the job and supply adequate fueling for the LE h/c package you're later planning on
you have to remove the valve stem seals to remove the "seat" for the stock springs so no reason to reuse them
Old Sep 25, 2009 | 02:01 AM
ebeard's Avatar
so anybody done a complete rebuild on an lt1? What did it cost you?
Old Sep 25, 2009 | 02:09 AM
BLK,97,T/A,M-6's Avatar
http://www.summitracing.com/parts/FEM-CSMHP766-300/ Would do the trick.
Old Sep 25, 2009 | 09:14 AM
myltwon's Avatar
what kind of rebuild? stock? bored over? new rotating assembly?
the cost of the rebuild will cost be determined by what you need and want to replace.
for a point of a reference the machine work on my block cost about $450 and included:
-hot tank
-freeze plugs
-cam bearings
-deck
-bore
-hone
Old Sep 25, 2009 | 10:48 AM
ebeard's Avatar
The number one cylinder just has 25% compression. I just need to fix that and install the cam and springs. It was rebuilt 40 k miles ago so i would think the block was reconditioned then. So basically just taking everything apart and putting it back together. (If it's just the rings) I guess i might end up needing a new piston possibly. what else could cause the loss of compression?
Old Dec 1, 2009 | 12:07 AM
ebeard's Avatar
rather than start a new thread i figured i would use this one. I looked at the crane valve spring kit mentioned above and i would like to go with that. In the notes part of the product info it says NOTE (1): Requires 3/8'' type multi-groove valve stem locks.
NOTE (2): Requires 11/32'' type single-groove valve stem locks. just wondering if this is of any consiquence.
Second could anyone recommend some 1.6 RRs with a link? i'm looking at going cheaper with these but i would love to hear what the difference is in the stamped comp magnums and the more expensive aluminum ones thanks
