ewp weap hole
Old Sep 24, 2009 | 09:22 PM
Black30thz's Avatar
Default ewp weap hole
will installing an electric water pump fix a weap hole problem?
Old Sep 24, 2009 | 09:31 PM
myltwon's Avatar
a weap hole problem is typically due to a failing unit and is used to relieve pressure from the component, not 100% on that though.
so if you are replacing the mechanical component of the water pump with an electric unit it should in theory fix such a problem if the mechincal component was the problem in the first place.
Old Sep 25, 2009 | 01:22 AM
litch2004's Avatar
yes installing it will eliminate the problem. The ewp comes with a freeze plug that blocks off the mechanical shaft bearing and weep hole.
Old Sep 25, 2009 | 02:40 PM
RamAir95TA's Avatar
The weep hole is designed to do just that. When the impeller support bearings begin to wear, coolant will leak through the seals and exit the weep hole. That's how you know the pump is on it's way out.
Old Sep 25, 2009 | 06:27 PM
Black30thz's Avatar
thanks for the help
Old Sep 27, 2009 | 06:12 PM
formula vincent's Avatar
Default weep hole
better hurry up and fix that you dont want coolant to leak into the opti .
Old Sep 27, 2009 | 06:49 PM
SS RRR's Avatar
Village Troll
The thing is the e-pump also has a weep hole and if you don't run the pump often enough the seal will dry up and you'll have a problem there too. You know how I know this?
