Possible fuel pump going bad?
Old Sep 28, 2009 | 09:39 PM
sepno77's Avatar
dose it start up right away??? have you gotten the codes read?
Old Sep 28, 2009 | 09:44 PM
whytryz28's Avatar
Now it starts up right away so far. Afraid to drive it still lol
No codes were thrown.
Old Sep 28, 2009 | 10:55 PM
sepno77's Avatar
honestly man it sounds more like an opti failure. my car is doing the same thing. it turns off on me when idle, while driving, when coming to a stop, hessitates, stutters, spits, backfires. the symtomes are wores when the car gets warm or hot too. all these are symptoms of opti falure. From what i was told is the sensor in the opti that keeps track of the cam gets weak loses the position and the car shuts off as a safety.
Old Sep 29, 2009 | 07:05 AM
whytryz28's Avatar
Oh joy lol
But when I hooked the fuel gauge up and gave it gas, the pressure dropped as the rpms climbed. That supposed to happen?
Old Sep 29, 2009 | 07:53 AM
whytryz28's Avatar
I just went back out to recheck everything and the only thing that changed were
Key on engine off - 36psi (previous was 38psi) Supposed to be around 41-43psi
Idle- The needle keeps jumping between 36-38psi still, Not sure what idle PSI is supposed to be.
Im gonna change the filter and see what it reads. I think its the pump and not the opti, I can hold the rpms and it wont stutter with decent fuel.
Old Sep 29, 2009 | 08:31 AM
whytryz28's Avatar
Ok, so I figured id throw some real world driving at it this time.
Brought the engine to running temp. fuel psi still at a low 36. Around 2-3k it started to break up and pop and the fuel pressure would drop to around 34psi before the stuttering stopped.
Does this sound like a pump issue still or Opti? Or is it bothe because the fuel drop and poping?
Old Sep 29, 2009 | 08:58 AM
trippinholyman's Avatar
i still say its the pump. when you give it gas the pressure should rise. that pressure is a bit low for idle, too. did you do any wot readings? did it shoot up when you did, if you did them? if not, then the pump is probably on its way out. if it can't deliver the adequate fuel pressure, you aren't going to get enough fuel, and its gonna stumble from the weaker combustion. ever run out of gas, esp in these cars? notice how when there is hardly any fuel left, the shifter and engine stumbles and moves around irregularly right before being shut off? same thing..
i still think its fuel related. you can run it because you have close to adequate fp but you don't have enough to drive it around reliably and you don't wanna do that anyway since the pump is on its way out
get the racetronix pump / harness, cut a hole above the gas tank and change the pump. if thats not it, well, you have a leak somewheres. but that should be easy enough to find if you do and then you'll have a brand new racetronix kit
Old Sep 29, 2009 | 09:10 AM
whytryz28's Avatar
I brought it as high as 4k rpm and the fuel pressure did not increase one bit.
I have the racetronix wire kit on the way and about to buy a walbro from the sponsor here who is selling them to ls1tech members for $99 shipped.
Old Sep 29, 2009 | 09:22 AM
wish that was going on when i needed a fuel pump. good luck man, it does sound like its on the way out. i doubt extra voltage through a new wiring harness will help that out but with a new pump too it'll be stronger than the day the dealer sold the car haha good luck
Old Sep 29, 2009 | 09:36 AM
LT1TA's Avatar
wierd, my car is a ls1 and it's doing the same thing. only in heavy traffic does it cut off though...
Old Sep 29, 2009 | 09:54 AM
whytryz28's Avatar
And you dont have an Opti so im feeling better about it being my pump now lol
Old Sep 29, 2009 | 11:52 AM
  #32
ls1 cars have a different pressure spec, i'm not sure on the numbers though don't have my book here with me at school so don't use the 41-47 3-10 less for idle and steadily rise up to 41-47 as throttle is opened.
i think the pressure is a little bit higher don't quote me on that though
Old Sep 29, 2009 | 02:13 PM
  #33
LT1TA's Avatar
ok, i'm sure it's fuel related, i just bought the car recently, but i'm using this as an excuse to get a new boost ready motor. wifey doesn't have to know.
Old Sep 29, 2009 | 02:46 PM
  #34
sepno77's Avatar
well i agree fuel should not be droping whille rpms are rising. this should be #1 consern at this time. tell me this. when you smash the gas can you still reach your readline before the car shifts or dose it shift early? if your car shifts early and acts like its hitting the rev limiter at like lets just say 4500 then its definatly ur fuel pump. if your still able to reach your redline then I would assume that your fuel pump is working fine as it has enouph fuel pressure to get up there in the rpm's. however if you are absolutly positive that the fuel pressure is droping far enouph to give you trouble then go ahead and throw money at it and see if it fixes the problem. who knows u might get lucky.
Old Sep 29, 2009 | 03:16 PM
  #35
RamAir95TA's Avatar
A drop in fuel pressure with a good regulator and pump could also be caused by a stuck/leaky injector.
How fast does the pressure bleed down with the KOEO?
Old Sep 29, 2009 | 07:13 PM
  #36
whytryz28's Avatar
It doesnt go past 3500rpm when I mash the peddle, it just sputters big time.
Old Sep 29, 2009 | 07:22 PM
  #37
97lt1camaro's Avatar
Not the pump.
When my pump went out mine wouldnt even hold pressure key on engine off. When it would FINALLY start after like 3-4 priming attempts, the idle was about 43psi. I taped the guage to the windshield and took it for a rip, it would drop to 25psi and the car still ran fine. Pulled alot stronger once i changed the pump, but it still ran fine.
Something else is going on with your car buddy.
Old Sep 29, 2009 | 07:24 PM
  #38
whytryz28's Avatar
Originally Posted by 97lt1camaro
Not the pump.
Injectors? Why else would the fuel drop when the rpms increase?
Old Sep 29, 2009 | 07:29 PM
  #39
I should rephrase my previous statement, i HIGHLY doubt its the pump.
No idea man, but i severly doubt its the pump. Only way to know for sure is to tape the guage to the windshield and drive it around till it starts doing it and see.
Old Sep 29, 2009 | 07:33 PM
  #40
whytryz28's Avatar
When its a cold start the motor idles ok, when it warms up and i mess with the throttle is when it stumbles. But it idles fine.
