Possible fuel pump going bad?
So I took another car, 3 hours later I go to start it again and I hear the pump prime and it fires right up...now did the pump overheat?
Should I just use this as an excuse like every other time to upgrade?
If the pump is bad, look into the Racetronix pump/harness kit. They are very much worth the $$$.
Would this be the pump:
http://www.racetronix.biz/itemdesc.a...PA-003&eq=&Tp=
And this the harness:
http://www.racetronix.biz/itemdesc.a...WH-003&eq=&Tp=
Idle-36-38psi
Vacuum line pulled - 48psi
When I gave it some throttle from the engine, the PSI dropped.
What does all this tell me?
at idle it is anywhere from 3-10 psi less so really it can be anywhere between 31 and 44. at wot it should be 41-47, which is odd because to simulate wot you take the vac line off the regulator and you have enough fuel pressure... your pump did overheat since it shut off... i would venture to say it is on its way out, ive had nothing but problems with gm fuel pumps. unless your fuel filter is clogged or there is a very small leak somewhere its probably on its way out. the racetronix kit is a good one and i have heard nothing but good things about it on here and other sites and from people i know, it gives the pump more voltage and its a walbro and its rated at 255 lph. runs better and stronger.
obviously your reg is good cos its not leaking any fuel past.
if you are gonna cut an access panel it would be a perfect excuse, even if it doesnt fix it haha you can do 30 min fuel pump changes and youll have the bitchin racetronix kit for when you DO fix it.
stutter and pop could be either...did it throw any codes like random misfires and stuff? when you run out of fuel itll do that, but if you have a bad icm or something it would be able to do that too.
lol im an idiot 95ta told you all that
i say go for it no reason not to upgrade your fuel pump haha
since your psi dropped when you gave it throttle theres something wrong somewheres. maybe taking the vac line off the reg is a bad test because the engine isnt under a good amount of load and it merely simulates? hence why you tape a gauge to the windshield and pray that you can go out on the street to floor it haha
Try this... Turn key on letting it fully prime, shut it off wait 30 seconds then repeat this a handful of times. If the sound of the pump changes its your pump...
