got one for you guys
well the car wouldn't start and if it did, it ran like **** so we decided to throw a new opti on it. boom, car started and idled pretty well. my buddy took it for a few short drives and he would always say it had pretty good power, but occasionally died at a stop sign. i'm thinking O2 sensors, no big deal.
so i hope in it last night and decide it could just need to be driven and cleaned out a bit. so as i'm driving through town on my way to the interstate, car runs pretty well. i didn't feel like it had as much power as it should, but whatever.
get on the interstate, set the cruise at 70 and cruise for about 10 miles with no issues. tap the brake to release the cruise, give it about 60% throttle just to see what she's got...car stumbles, check gauges light comes on and she dies. have to pump the gas to get her to restart as i'm rolling on the interstate. get off on the exit, she dies at the stop sign. pull back on the interstate to head back and it has absolutely no power. at 60 it was running 3500 rpms and then i noticed the oil pressure was at about 10 pounds...i start shitting my pants.
get it back to my buddy's and he comes running out and swears he heard something rattling. we pop the hood and the antifreeze is boiling, but the gauge never went up until after i turned the key back on. oil pressure stayed low.
any damn ideas? i'm getting really tired of fighting this thing. my mods are in my sig, Ion tuned it and the cam is the AI 226/234
thanks guys
1. how is your compression
2. gap your spark plugs correctly?
3. your cam might be off a tooth
4. make sure your fuel pressure is at least 40lbs and is your pump stock? how many miles?
spark plug is at 35
messed with the timing a few times so its correct now, lol
fuel pressure is good and its the second pump which has seen maybe 10k miles
and i never had a check engine light come on...just the check gauges light when i hit the gas and she started to die
changed the plugs last night along with the oil. looks like there was some gas in the oil. so that's at least fresh now. plugs didn't look too bad but it never hurts to change them. still get a weird idle. idle goes from 1100 to about 700 and keeps doing that. i plan to change the o2 sensors one of these days when i have more time
if you would like to check for a leaky injector, lift the fuel rail and put the key into the on position (priming fuel pump) and check for any fuel to come out. I don't think an injector is the issue as this problem wasn't existant before the cam swap. my advice would be to look at anything that was removed during the swap that could be damaged/incorrectly installed
I have no idea why two of them were stuck when I started her up, but they were. After removing them I tried cleaning them but never could get them to close.
you cant get it timed right either can you?
we went over everything else thoroughly hoping we wouldn't have to tear everything back down...but now we know its somewhere in the set up so back off it all comes, lol
i will keep ya informed on the progress!
