in 8 hours, car suddenly won't start
I finished a motor swap on my friends 94 Formula. It started and ran for two days, we drove it around town, checked fluids, etc. More or less made sure it was road worthy. His wife drove it to work yesterday morning, she tells me the car ran great and had no issues. Well when she got out of work, it cranks but doesn't fire off.
What can cause it to all of a sudden not fire off? Going to get a fuel pressure gauge today to see if the filter got clogged or something. You can hear the pump prime, then it will crank. Doesn't backfire. I guess after I check the fuel pressure I will pull a plug and see if we have spark. I'm just amazed that this car was perfectly fine, and then after sitting for 8-9 hours while she was at work the damn thing won't start.
This same thing happened to me I drove it to school just fine (destroyed an srt4 that day on the way) parked it, then when I came out 5 hours or so later to leave it just turned over but wouldnt start. I had my friend jiggle the ignition coil wires and it started right up. Ended up being a bad ground off the ignition coil.
Alright, its just amazing then that it ran 7 times without it then?
jarretthise the new used motor was not run for about two months. Most stuff came over from the factory motor. It was interesting, motor came out of a 60k Impala that the owner put ported fbody heads on with a 503 cam. So I had to change a few things, but the car did run for about 3 1/2 hours before this. A few trips between my friends house and mine, and his wife took it to work.
i ran my car not knowing that my FPR wasnt hooked up to anywhere for afew months but then that went bad on me suddenly and the car stopped running right. i replaced everything as a result of that. FPR, pump, filter injectors and then got it returned and it ran great.
that was afew months ago. last night i was driving down the road and everything was perfectly fine. i went from 4th-6th at 50 cruising and the car started running like absolute CRAP. i didnt know what it was. i go to my friends house right down the road and at first i thought it was my pump. i pulled the line coming off my month old FPR and fel thte hose at idle (barely running) and there wasnt any vacuum that i could feel. i pulled the line from the intake before it goes to that 3 way splitter thing and it had plenty of vacuum. sorry for the long *** post but im hoping its just my FPR again :\ and yours too. GL and let us know what happens
didnt really read all of this..
is it cranking?
if not, check your neutral safety switch.
put it in park or neutral, turn key on, and lay under it, and jump the solenoid on the starter, if it starts, NSW is bad.
aaron
is it cranking?
aaron
If you have fuel pressure and spark, check to make sure your bellows didnt come off or loose, The will run like **** or not start at all if it is not reading the correct air flow from the mass air sensor.
But basicly you need to see if you have spark, fuel, both or niether.
i checked both of those. took all the wires off checked them and put them back. everlastings in ok shape there. i beat my FPR alittle and the car runs alittle better. but still runs like crap in the low RPM range. around 3k+ tho it feels like its running better... hmm. ill have ot hook up a fuel pressure gauge and see what its at.
OK so finally got a pressure tester on it, on initial prime there is 40 psi. So we have fuel. We pulled the number 1 plug and stuck it to the header, then to the block, whatever I could find for metal. There is no spark. I mounted the ground wires there behind the stud, directly to the block. They all seem fine.
Thinking of swapping the coil first. Have two spares of them laying around. They are at my house of course, forgot to drag them over to vulcan2422's house.
Stuck a vacuum line from the FPR to the intake manifold, no difference. Well I guess it wouldn't as there is no spark.
Started running though some of the stuff on shbox. We have 10+ vdc on A,D. Do not have 1-4 vac on B, taking the readings from the ICM connection. Going to keep reading on the site to try and narrow it down some more. All I know is it was running great and then it would crank but not fire, so obviously something failed on shutdown or on startup.
Looking at shbox I have no idea where to go next. Read the opti harness end to end? Can I read on the four wires where the harness connects up top for the opti signal?
