Weird oil question?
to the OP does it smoke when you beat on it when it's hot (besides WOT)? I hardly ever used to beat on my LT1 until oil temps were 180*. If if goes away when hot, then the rings are probably the point to blame, but could also be the valve stem seals, but usually those cause blue smoke on immediate startup.
Another WTF>.. anything group IV V, or VI is a synthetic when it comes to basestocks. There is nothing "being as close as you can get". It's argued the 5 and 10w30 M1 are a GRP III, but none have offered 100% proof. The dealer doing an UOA won't show what kind of oil is in the car. No such test.. That test will show what viscosity the motor oil is, and if you had the wrong viscosity in there, and they can show that's the cause of failure then yes they can deny warranty.. Not the BS you just mentioned.
RP is good, but way overpriced for what it is. M1, PP, Amsoil, Syntec, Synpower are all good oil.
OP when's the last time you replaced your PCV valve, and inspected your PCV hose assembly? How about the fresh air hose on the pass side valve cover? Ever Clean the TB?
The smoke on cold start is absolutely valve stem seals.
And no, switching from conventional to synthetic won't hurt a thing, assuming a good, clean engine to start with. At worst, you'll see a leak or two that wasn't there before.
Ok so here is why syn oil doesn't break down as fast and the molecules are smaller in syn so it gets places where con can't. So therefore syn lasts longer and is smoother lubing..not only that bu the molecules are different style and your motor has adapted to them. You can't just swap between the two and expect it to just be ok. Well you can but your motor won't last for ****.
For the op I wouldn't listen to the guy telling you it's ok. He must work at jiffy lube!! And yes swapping can take out more than just seals and rings. It can even cause your bottom end to go out with low oil pressure because your pump goes to **** or something.
Dude HIGH END RACE LUBRICANTS more often than not are not API rated oils, and therefore DO NOT BELONG in a daily driven vehicle. Most Amsoil, Royal Purple, etc do not fit into that niche. We're not talking VR1 (non street legal) or Joe Gibbs oil or something.
Again Sorry, most all motor oils contain Zinc, Calcium, etc. Unless you tell someone the oil they are testing, a UOA will not point out what it is. Granted if they asked you for a virgin sample of your oil, they could get on BITOG and find a match, but I doubt a dealer would do that. END OF STORY.
OMG look at all the metal in this HIGH END Race Lube.. OHH wait it's just Mobil Clean 5000 10w30 from my wife's car. Hey look even 1ppm of TitaniuM!
