cam
Old Oct 6, 2009 | 01:04 PM
95sscamaro's Avatar
Question cam
i have a 95 Z, it has 118,xxx and i want to put the cc306 and a top-end, how long would the bottom end last? looking for a weekend warrior, maybe take it to to the track once a month.
Old Oct 6, 2009 | 01:29 PM
the_merv's Avatar
As long as you maintain it it'll hold up.
Old Oct 7, 2009 | 12:44 AM
gregrob's Avatar
Depends on how high you wind it too. I'd look for a cam that didn't want so many rpms.
Could pick a much better cam for stock bottom end.
Old Oct 7, 2009 | 12:46 AM
texas94z's Avatar
m6 or a4?
Old Oct 7, 2009 | 01:01 AM
BLK,97,T/A,M-6's Avatar
Keeping the r's low is important. The opti, and rod bolts dont like hi rpm's.
Old Oct 7, 2009 | 05:47 PM
95sscamaro's Avatar
its a M6. i priced doing a cam and heads and its around $2000-$3000, but for $4000-5000 i could have a 383.
Old Oct 7, 2009 | 10:10 PM
texas94z's Avatar
Buy a kit and spray that lt1. You can make some sick power with bolts ons and a 150 shot.
Old Oct 7, 2009 | 11:21 PM
94LTZ's Avatar
My first build i did was at 135,000 with just a top end rebuild, headers, injectors, gears, and a CC305 with full supporting vavle train.. It ran great and i was running it up to 6300 RPM and it held up, if you take car if your car i think you'll be fine man, and nitrous does wonders but is very addicting
Old Oct 7, 2009 | 11:24 PM
94LTZ's Avatar
And as far as doing the 383 build i'm sure you can do it for that but you might as well wait and save up more cause whe you start getting into it you always seem to want more expensinve stuff and more power and before you know it that price tag just went to 7,000 to 8,000 lol
Old Oct 8, 2009 | 12:32 PM
95sscamaro's Avatar
this is true, i think just doing the cam+heads i will be were i want to be. im looking for around 450-500HP @ the flywheel, i would be happy.
Old Oct 8, 2009 | 03:33 PM
StealthFormula's Avatar
Trust me in the end it will cost alot more than you think. Don't forget all the cost in valvetrain, injectors, fuel pump, couple hundred in gaskets, manifold porting, TB, head bolts, etc. etc. Figure $3500 for just a heads/cam swap.
Old Oct 8, 2009 | 04:16 PM
95sscamaro's Avatar
wow i didnt know that i had to do the injectors and the fuel pump? how do you pick what ones?
Old Oct 8, 2009 | 04:22 PM
Depends on how aggressive the heads and cam are in terms of the injectors. Some SVO 30's usually do the trick if not some 36's would be good. The best fuel pump kit IMO is the Racetronix 255.
Old Oct 8, 2009 | 08:24 PM
95sscamaro's Avatar
the cam is the cc306 and i think im going to go with trickflow heads, im trying to buy everything at Summit, do they sell them?
