Any reason why I cant use stainless water pump bolts?
Having to replace that @#$%ing water pump drive seal and I have noticed some normal corrosion on the bolts.
Any particular reason why I cant use stainless water pumps bolt when putting the pump back on? Any dis-similar meat issue that might cause a problem?
The joys of using SS (as you probably already know) is that it resists corrosion, therfore, as a more "inert" type of material (i.e. - the outer valience shell is filled with electrons - so it acts as a closed system), the movement of electrons to or from it is greatly reduced (relative to normal CR Steel, or Al, or Fe); so, none of the normal corrosion or galvinic (forgive my spelling!) / battery type issues when contacting Al or Fe.
Short Answer: Do it!
Hey:
I used long stainless Exhaust studs with copper eaze sealant, stainless washers, and nyloc nuts, I used to take it off more than I do now that I have an EWP. but no leaks ever and real easy to take on and off the pump housing. I have this setup on 4 cars so its not just a 1 shot deal.
Dub
When In Doubt Do Without
Dub
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
