LT1 Valve train noise help.
My buddy has a 95 Z LT1 car. It has GM performance parts hot cam Hydraulic roller, 1.6 rockers with poly locks, lifter set, springs.
He decided one day to go out and do some donuts with it.The car sounded fine. He parked the car for a few days and went to move it outside of the garage when he heard a ticking noise from the passenger side valvetrain. He checked his oil pressure and it was at 40PSi cold and once warm 24 PSi warm which is what its always at.
Last night we pulled the valve covers off of it thinking maybe a collapsed lifter. I did the push on the pushrod test to see if the lifters would get spongy and they were all pumped up and hard as a rock. The valves are adjusted properly(not to tight and not to loose) I checked all the rocker arms, pushrods, cam, and everything still looks new no premature wear, nicks chips, hot spots.
The cam,lifters and rocker arms springs only have 2,000 miles on them.
Anyone have any ideas?
Might try that.
It might be an exhaust leak but I doubt it as the sound is coming from on top of the head.
The pushrods were all checked and are straight as an arrow. We checked them on glass.
This was your problem? I am having the same noise you are talking about and I ran across this thread while researching.
