breaking up after 4500
Once I redid what the dealership monkey did and un-Zip tied my wires (!!!), then routed them with aftermarket wire seperators, MY car's high RPM miss was fixed.
I know our engine compartment is tight, but this might be what you need to try.
Oh, and I can tell you that zip-tieing three pass side plug wires (tightly!) to an A/C bracket will indeed result in a nasty high speed miss - even with new wires!
Another problem i had was a bad ignition coil.. The MSD coils are decent and like 40 bucks at autozone. And like mentioned before it could be the icm.
what gap are you running on those plugs?
the fact that you're saying it runs poorly after running for a while leads me to believe it is something else honestly:
heatsoak, which usually means old/bad electronics that are more prone to problems when being exposed to heat sources for prolonged periods of times. this could be anything like a fuel pump, icm, electrical connectors, grounds, wiring, coil, etc. I've seen opti connectors that run along the side of the intake cause this problem due to dry rotting. one time I even had an ICM not being bolted correctly to the coil bracket cause a high rpm miss.
Your Gap is awfully big. Do you have an aftermarket ignition box? If not , I would definiteley close the gap to atleast a .040
It could very well be the ol opti tho.. good luck man..these kinda gremlins can drive ya nuts lol
