Future Modifications
Old Oct 13, 2009 | 07:59 PM
myltwon's Avatar
what gear do you currently have? 2.73 or 3.23?
the 93s had an M28/M29 transmissions which are geared lower than the 94+ T56 (3.36 first gear in the M28 vs 2.66 in the T56) and as steep of a gear is not required to get a similar result. I'd say 3.73 should be a good gear, especially if you're plan on hitting it with a bottle
Old Oct 13, 2009 | 08:20 PM
nik1703's Avatar
3.23 is in the M6 in 93' if I am not mistaken? Right?
Old Oct 13, 2009 | 08:29 PM
myltwon's Avatar
depends if you have the GU2 (M28/2.73) or GU4 (M29/3.23) RPO code
Old Oct 13, 2009 | 08:32 PM
tbird31's Avatar
This man speaks the truth. I completely forgot the fact you had a 93 car. If you have the M28 trans I'd definitely do 3.73s unless it's a track car because 1st gear will be useless if you put in 4.10s. Either way, yea, I think a set of 3.73s will make the car SOOO much more enjoyable. I know gears are the awakening factor to 99% of the people I talk to about modding. They usually say that they had wished they did gears sooner because it makes the car so much more fun to drive.
ninja edit: WOOOOT 2000th post. haha. Sorry had to.
Old Oct 13, 2009 | 08:38 PM
nik1703's Avatar
hahahha congrats.
Ummm, 1st gear is already almost useless, I have a really hard time hooking unless the weather is perfect and the tires are warm. How do I figure out which I have?
Old Oct 13, 2009 | 08:45 PM
myltwon's Avatar
look for the code in the glove box I believe: GU2 or GU4
Old Oct 13, 2009 | 09:05 PM
RamAir95TA's Avatar
Originally Posted by nik1703
What about 3.73's? worth it?
Not as much as 4.10s. No idea why you'd think you'd "blow your diff."
Old Oct 13, 2009 | 09:14 PM
nik1703's Avatar
Cool... I'll check it out. Which is which?
A few dudes on here said they went through 2 sets of gears because of the 4.10s. I dunno. That's just what I heard.
Also, I don't want to lose cruise-ability. I drive to vegas every few months and other trips. 4.10s wont kill me?
myltwon's Avatar
the 93 6 speed transmissions are geared differently than the 94+ t56's, they're steeper geared
the GU2 is the 2.73/M28 and the GU4 is 3.23/M29 I believe
Old Oct 13, 2009 | 09:18 PM
nik1703's Avatar
EDIT okay so i looked in my glovebox and there was a sticker that said parts identification with a big list of 3 digit codes. One of them was GU5 and another was M29. That's the only thing close to the transmission related codes you guys gave me.
Old Oct 13, 2009 | 09:23 PM
myltwon's Avatar
I assume that would means you have a M29 with 3.23 gears
Old Oct 13, 2009 | 09:26 PM
  #32
nik1703's Avatar
cool so you guys would say 3.73's then?
Old Oct 13, 2009 | 09:28 PM
  #33
myltwon's Avatar
I'd say so
Old Oct 13, 2009 | 09:39 PM
  #34
nik1703's Avatar
http://www.ws6project.com/user_stor/...oducts_id=1292
how do these look? how much will the install run me?
Old Oct 13, 2009 | 09:42 PM
  #35
gregrob's Avatar
Uhh, I dont think it's 2:73 / 3:23.
The options were 3:23 or 3:42....
No 2:73's in a M6 car
Old Oct 13, 2009 | 09:43 PM
  #36
myltwon's Avatar
93 didn't have a 3.42 option, it didn't have a T56 like 94-02, had the M28/M29 which is geared different so the rear gear ratio options were different
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU2)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
Old Oct 13, 2009 | 09:52 PM
  #37
nik1703's Avatar
http://www.summitracing.com/parts/SUM-741001/
actually these are cheaper, $150 summer 3.73 gears.... anybody have any experience with these? how much should install cost?
Old Oct 13, 2009 | 10:07 PM
  #38
tbird31's Avatar
get your facts straight bud, read the thread. we've already gone through the M28/M29 and 2.73 and 3.23 dealio twice.
to the OP, yea man I think you'd really enjoy a set of 3.73s. Gears are definitely something you wouldn't want to skimp out on. Buying a quality set of gears is a good thing. Less whine, less chatter, better wear. I'd set aside $300ish for install, I'd also recommend buying a cover to go along with the gears/install. It'll help strengthen it as well.
uhhh what I'd give for a M29 trans...lucky bastard. lol
Old Oct 13, 2009 | 10:11 PM
  #39
gregrob's Avatar
Yep, I found it on another site too. I WAS WRONG lol
Old Oct 13, 2009 | 10:13 PM
  #40
nik1703's Avatar
Why/??? isn't the T-56 a better transmission??? Or do you say so because of the ratio?
Hmmm, i'll have to check summit for a cover. Is that really necessary?
