Help Engine Noise/tick loud after oil change
Old 10-18-2009, 10:51 PM
DVS BSTD's Avatar
yeah in my stang I ran Mobil and VR1 oil.....I figured I'd give royal purple a try
Old 10-18-2009, 10:59 PM
Black96transam's Avatar
i did too.. and i wasn't happy
Old 10-19-2009, 12:07 AM
moderate Z28's Avatar
The factory calls for 5w-30 when the car and engine were new. Its far from new anymore.
Dont worry about what the manual says about oil weight. I use 20w-50 in mine and have been for the last 6 years since I bought it. It doesnt get too cold down here though.
Old 10-19-2009, 01:35 AM
DVS BSTD's Avatar
moderateZ28 you dont live too far from me....I guess I'll try 20w50
Old 10-19-2009, 07:50 PM
Chris97z's Avatar
Ok the noise is back. I got under the car and I can hear it well where the transmission connects to the back of the engine. I cant hear it with my ear against the oil pan. Its also fairly loud at the passenger side valve cover.
Old 10-19-2009, 09:07 PM
67goatman455's Avatar
check your torque converter bolts. start there
Old 10-19-2009, 09:17 PM
3rdgen92maro's Avatar
Have to agree with you on that one. In my 91 z28 I had the converter bolts loosen up and let me tell you it sounded like the rods where about to come through the block...tightened them up and the noise was gone. So I say check the converter bolts to if its an auto.
Old 10-19-2009, 10:58 PM
myltwon's Avatar
Originally Posted by hitmanws6
your use of lucas negates the thicker weight of oil. all lucas does is thin out oil and make it foamier. NEVER use oil additives.
+1 every see those displays on counters at part stores with the gears and the crank comparing lucas to reg oil? spin the lucas one fast enough and that bitch will sud up like dish soap. def not something I want
Old 10-20-2009, 02:05 AM
Chris97z's Avatar
How do you tighten the torque converter bolts? Are they just under the inspection cover?
Old 10-20-2009, 07:53 AM
myltwon's Avatar
you take the tc inspection cover off and they should be right there
Old 10-20-2009, 08:38 AM
Make sure you get all of them, you have to spin the engine to find all of the bolts which isnt always that easy to do. Make sure you have plenty of light to see what your doing.
Old 10-01-2010, 09:26 PM
  #32
frantic318's Avatar
Chris97z did you find out what the ticking problem was? my car has the exact same problem
Old 10-01-2010, 10:31 PM
  #33
gregrob's Avatar
20-50 is retarded. That 0-30 GC is good oil and as thick as most 40 weights. People need to di some damn research
Old 10-01-2010, 10:53 PM
  #34
Gojira94's Avatar
'Bout time for BOB to drop in... meanwhile, here's a little light Friday night reading:
http://www.bobistheoilguy.com/cms/in...d=48&Itemid=55
Old 10-01-2010, 11:14 PM
  #35
ebeard's Avatar
Originally Posted by Black96transam
well i haven't heard of lucas thining out.. but if it does then new one on me.. i put royal purple in my motor too... didn't like it.. mobile one 10w-40 now
What didn't you like about the royal purple?
Old 10-02-2010, 04:01 AM
  #36
StealthFormula's Avatar
Agreed. A 50w oil in an LT1 is IMO unecessarily thick.
Everybody sees 0w and assumes there is no weight to it...wrong! It is simply an empirical number. I run Amsoil 0w30 in my vehicles.
Old 10-02-2010, 10:16 AM
  #37
93BlackZ28's Avatar
Originally Posted by LT1
LT1 engines have loud valve train in general so you might have just got scared thinking there was a problem. Just wait till you install aftermarket rocker arms they get really loud.
Ain't that the truth
Old 10-02-2010, 12:12 PM
  #38
95' Bird's Avatar
Originally Posted by projekt70chevelle
Deff. sounds like rod knock/valvetrain noise. DON'T RUN THE ENGINE ANYMORE!! Check the oil level, if its low (or empty) you either forgot the oil, or didn't tighten down the drain plug or filter. If it's full, you may have had something caught in the filter and clogged up your oil galleys or got some of the plastic protector rap stukk in the oil pump output port. If none of these are the case, your oil is probably bad (i.e. coolant in the oil or poorly produced oil that is waaay too thin and waaay under spec which to be honest is EXTREMELY unlikely)... either that or you had some coincidental major engine failure that just happened to occur at the same time
the lifter on my 3.4l has a slight pecking always at idle now, could be that...it used to only do it for the first 10seconds on cold start
Quick Reply: Help Engine Noise/tick loud after oil change
